上图为加密解密结果。
TEA加密解密比较快也非常简单,当然也很难攻破,加密强度与加密轮数成正比,下面编写的代码中加密轮数为16. 密钥是128bits。
#include "stdio.h" #include "string.h" #include "stdlib.h" typedef unsigned char uint8_t; typedef unsigned short uint16_t; typedef unsigned int uint32_t; #define TEA_DELTA 0x9e3779b9 #define TEA_ENCRYPT_TIMES 16 static const uint8_t tea_fill_data[8] = {0x12,0x23,0x34,0x45,0x56,0x67,0x78,0x89}; static uint8_t tea_key[16] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16}; int tea_set_key() { uint8_t i = 0; printf("enter your key (16bytes): \n\r"); for(i = 0;i < 16;i++) { scanf("%d", &tea_key[i]); } return 0; } int tea_fill_buff(uint8_t *text, uint32_t size) { uint32_t i = 0; if((size & 0x7) == 0x0) { return size; } for(i = 0;i < (8 - (size & 0x7));i++) { text[size + i] = tea_fill_data[i]; } return (size + i); } static int tea_encrypt_group(uint32_t *text, uint32_t *key) { uint32_t sum = 0, v0 = text[0], v1 = text[1]; uint32_t k0 = key[0], k1 = key[1], k2 = key[2], k3 = key[3]; uint8_t i = 0; for(i = 0;i < TEA_ENCRYPT_TIMES;i++) { sum += TEA_DELTA; v0 += (v1 << 4) + k0 ^ v1 + sum ^ (v1 >> 5) + k1; v1 += (v0 << 4) + k2 ^ v0 + sum ^ (v0 >> 5) + k3; } text[0] = v0; text[1] = v1; return 0; } static int tea_decrypt_group(uint32_t *text, uint32_t *key) { uint32_t sum = TEA_DELTA * TEA_ENCRYPT_TIMES, v0 = text[0], v1 = text[1]; uint32_t k0 = key[0], k1 = key[1], k2 = key[2], k3 = key[3]; uint8_t i = 0; for(i = 0;i < TEA_ENCRYPT_TIMES;i++) { v1 -= (v0 << 4) + k2 ^ v0 + sum ^ (v0 >> 5) + k3; v0 -= (v1 << 4) + k0 ^ v1 + sum ^ (v1 >> 5) + k1; sum -= TEA_DELTA; } text[0] = v0; text[1] = v1; return 0; } int tea_encrypt(uint8_t *text, uint32_t size) { uint32_t number = size >> 3; uint8_t i = 0; if(text == NULL || (size & 0x7) != 0) { printf("param invalid %d ....",(uint8_t)(size & 0x7)); return -1; } for(i = 0;i < number;i++) { tea_encrypt_group(&(((uint32_t *)text)[i * 2]), (uint32_t *)tea_key); } return 0; } int tea_decrypt(uint8_t *text, uint32_t size) { uint32_t number = size >> 3; uint8_t i = 0; if(text == NULL || (size & 0x7) != 0) { printf("param invalid %d ....",(uint8_t)(size & 0x7)); return -1; } for(i = 0;i < number;i++) { tea_decrypt_group(&(((uint32_t *)text)[i * 2]), (uint32_t *)tea_key); } return 0; } int main() { uint8_t sel; uint8_t tmp_buf[128]; uint32_t count, i; printf("*********************************************\n\r"); printf("******TEA encryption and decryption *********\n\r"); printf("*********************************************\n\r"); while(1) { printf("***1. enter your key \n\r"); printf("***2. data encryption \n\r"); printf("***3. data decryption \n\r"); printf("***enter number : \n\r"); scanf("%d", &sel); switch(sel) { case 1: if(0 != tea_set_key()) { printf("fail to create key ... \n\r"); } break; case 2: printf("enter your information: \n\r"); scanf("%s", (char *)tmp_buf); count = strlen((char *)tmp_buf); count = tea_fill_buff(tmp_buf, count); printf("::::\n\r"); tea_encrypt(tmp_buf, count); for(i = 0;i < count;i++) { printf("%d ", tmp_buf[i]); } printf("\n\r"); break; case 3: printf("enter your data len: \n\r"); scanf("%d", &count); printf("please enter %d numbers: \n\r", count); for(i = 0;i < count; i++) { scanf("%d", &tmp_buf[i]); } printf("::::\n\r"); tea_decrypt(tmp_buf, count); for(i = 0;i <= count;i++) { printf("%c", tmp_buf[i]); } printf("\n\r"); break; default: return 0; } } }
大家也可以玩玩.....
