电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » PIC16F1826定时器实现呼吸灯效果主程序
2021-09-12 23:50:32     打赏
void main(void)
    TMR0IF=0;//清除TMR0中断标志位
    TMR0=255;//设置中断初始值255
    unsigned int k = 1;
    unsigned int TIMER0 = 0,TIMER1 = 0,TIMER2 = 0;
    unsigned char Flag_1 = 1;
    unsigned char Flag_2 = 1;
    unsigned char Flag_3 = 1;
    Pin_Init();
      Answ_Out = 0;
      Light1 = 0;
      Light2 = 0;
      Light3 = 0;
      Light4 = 0;
    while(1)
        if( (TMR0IF == 1) && (Flag_1 ==1) )           //开启定时器溢出中断
            TIMER0 ++;              //计数器+1
            TMR0IF = 0;             //定时器溢出标志位清零
            TMR0 = 255;
        if( TIMER0 == k )           //如果计数器的值等于设定的值
            Light4 = 1;             //灯灭
        if( TIMER0 == 100 )          //计数器加到90
            Light4 = 0;             //灯亮
            TIMER0 = 0;
            k++;                  //设定值初始化
        if( k == 99 )
            Light4 = 0;
            k =1;
            Flag_3 = 1;
            Flag_1 = 0;
        if( (TMR0IF == 1) && (Flag_2 ==1) )           //开启定时器溢出中断
            TIMER1 ++;              //计数器+1
            TMR0 = 255;
        if( TIMER1 == 40040)
            Light4 = 1;
            TIMER1 = 0;
            Flag_1 = 1;
            Flag_2 = 0;
        if( (TMR0IF == 1) && (Flag_3 ==1) )           //开启定时器溢出中断
            TIMER2 ++;              //计数器+1
            TMR0 = 255;
        if( TIMER2 == k )           //如果计数器的值等于设定的值
            Light4 = 0;             //灯亮
        if( TIMER2 == 100 )          //计数器加到90
            Light4 = 1;             //灯灭
            TIMER2 = 0;
            k++;                  //设定值初始化
        if( k == 99 )
            Light4 = 0;
            k =1;
            Flag_2 = 1;
            Flag_3 = 0;
