问题描述及复现步骤:
将eth1 网口设置成百兆网口, 但更新系统后,仍然显示千兆网口, 未配置成功
gamco 配置:
&gmac0 {
233 phy-mode = “rgmii”;
234 clock_in_out = “input”;
235 // clock_in_out = “output”;
236
237 /* snps,reset-gpio = 《&gpio2 RK_PD3 GPIO_ACtiVE_LOW》; */
238 snps,reset-gpio = 《&gpio0 RK_PD5 GPIO_ACTIVE_LOW》;
239 snps,reset-active-low;
240 /* Reset time is 20ms, 100ms for rtl8211f */
241 snps,reset-delays-us = 《0 20000 100000》;
242
243 assigned-clocks = 《&cru SCLK_GMAC0_RX_TX》, 《&cru SCLK_GMAC0》;
244 assigned-clock-parents = 《&cru SCLK_GMAC0_RGMII_SPEED》, 《&gmac0_clkin》;
248 pinctrl-names = “default”;
249 pinctrl-0 = 《&gmac0_miim
250 &gmac0_tx_bus2
251 &gmac0_rx_bus2
252 &gmac0_rgmii_clk
253 &gmac0_rgmii_bus
254 &gmac0_clkinout》;
255
256 tx_delay = 《0x3c》;
257 rx_delay = 《0x2f》;
258
259 phy-handle = 《&rgmii_phy0》;
260 status = “disabled”;
261 };
时钟配置::
433 gmac0_clkin: external-gmac0-clock {
434 compatible = “fixed-clock”;
435 clock-frequency = 《50000000》;
436 clock-output-names = “gmac0_clkin”;
437 #clock-cells = 《0》;
438 };
439
结果:仍显示千兆网卡
firefly@firefly:~$ dmesg |grep eth1
[ 5.969001] rk_gmac-dwmac fe2a0000.ethernet eth1: No Safety Features support found
[ 5.969023] rk_gmac-dwmac fe2a0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 5.969350] rk_gmac-dwmac fe2a0000.ethernet eth1: registered PTP clock
[ 5.971211] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 6.995233] rk_gmac-dwmac fe2a0000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 6.995319] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
共4条
RK3568网卡设置百兆失败如何解决这个问题呢?
关键词: RK3568 网卡
共4条
| 电子价签墨水屏开发被打赏¥35元 | |
