电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 怎么去解决ROC-RK3568-PCSEEC20板无法上网的问题呢?
共3条 1/1 1 跳转至页
2023-06-27 10:07:04     打赏
问题描述及复现步骤:
General  |              path: /org/freedesktop/ModemManager1/Modem/0
|         device id: 148b7e11716fd6b8d507b9d5322af03defac5a7b
Hardware |      manufacturer: Quectel
|             model: EC20F
| firmware revision: EC20CEHCLGR06A05M1G
|         supported: gsm-umts, lte
|           current: gsm-umts, lte
|      equipment id: 868274063130910
System   |            device: /sys/devices/platform/fd880000.usb/usb2/2-1
|           drivers: qmi_wwan_q, option
|            plugin: quectel
|      primary port: ttyUSB2
|             ports: ttyUSB0 (qcdm), ttyUSB1 (gps), ttyUSB2 (at), ttyUSB3 (at),
|                    wwan0 (net)
Status   |             state: failed
|     failed reason: sim-missing
|       power state: on
|    signal quality: 0% (cached)
Modes    |         supported: allowed: 2g, 3g, 4g; preferred: none
|           current: allowed: any; preferred: none
IP       |         supported: ipv4, ipv6, ipv4v6
板卡连接正常,用的电信卡,也正常。
关键词: ROC-RK3568-PC     EC20
2023-06-27 10:07:33     打赏
2023-06-27 10:07:49     打赏
先检查下 sim卡 是不是接错了
其次是接触问题,可以试下按压卡槽 或者 在卡背贴个贴纸增加下厚度;
共3条 1/1 1 跳转至页
