第一次使用HD32F460KCTA
官网下载了V3.1库,需要使用UART2,板已经画好了。选UART + DMA 例程
在库目录直接修改芯片,更换UART4 为UART2
SW仿真接口,用JLINK的自带串口跳线到UART2观察数据,串口助手收发没反应,
哪位高手,帮助指点一下,谢谢
main.c 的50--123行微改动
/* DMA definition */
#define RX_DMA_UNIT (CM_DMA1)
#define RX_DMA_CH (DMA_CH0)
#define RX_DMA_FCG_ENABLE() (FCG_Fcg0PeriphClockCmd(FCG0_PERIPH_DMA1, ENABLE))
#define RX_DMA_TRIG_SEL (AOS_DMA1_0)
//#define RX_DMA_TRIG_EVT_SRC (EVT_SRC_USART4_RI)
#define RX_DMA_TRIG_EVT_SRC (EVT_SRC_USART2_RI)
#define RX_DMA_RECONF_TRIG_SEL (AOS_DMA_RC)
#define RX_DMA_RECONF_TRIG_EVT_SRC (EVT_SRC_AOS_STRG)
#define RX_DMA_TC_INT (DMA_INT_TC_CH0)
#define RX_DMA_TC_FLAG (DMA_FLAG_TC_CH0)
#define RX_DMA_TC_IRQn (INT000_IRQn)
#define RX_DMA_TC_INT_SRC (INT_SRC_DMA1_TC0)
#define TX_DMA_UNIT (CM_DMA2)
#define TX_DMA_CH (DMA_CH0)
#define TX_DMA_FCG_ENABLE() (FCG_Fcg0PeriphClockCmd(FCG0_PERIPH_DMA2, ENABLE))
#define TX_DMA_TRIG_SEL (AOS_DMA2_0)
//#define TX_DMA_TRIG_EVT_SRC (EVT_SRC_USART4_TI)
#define TX_DMA_TRIG_EVT_SRC (EVT_SRC_USART2_TI)
#define TX_DMA_TC_INT (DMA_INT_TC_CH0)
#define TX_DMA_TC_FLAG (DMA_FLAG_TC_CH0)
#define TX_DMA_TC_IRQn (INT001_IRQn)
#define TX_DMA_TC_INT_SRC (INT_SRC_DMA2_TC0)
/* Timer0 unit & channel definition */
#define TMR0_UNIT (CM_TMR0_2)
#define TMR0_CH (TMR0_CH_B)
#define TMR0_FCG_ENABLE() (FCG_Fcg2PeriphClockCmd(FCG2_PERIPH_TMR0_2, ENABLE))
/* USART RX/TX pin definition */
//#define USART_RX_PORT (GPIO_PORT_B) /* PB9: USART4_RX */
//#define USART_RX_PIN (GPIO_PIN_09)
//#define USART_RX_GPIO_FUNC (GPIO_FUNC_37)
移植下V3.1的库出现的问题
| 电子价签墨水屏开发被打赏¥35元 | |
