电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【换取手持数字示波器】Ubuntu中QT5的安装
共10条 1/1 1 跳转至页
2024-03-31 14:37:47   被打赏 40 分(兑奖)     打赏
安装前准备1、判断gcc是否安装
判断: gcc -v
没有安装的话记得安装:
安装如下:
sudo apt install gcc
2、判断g++是否安装
判断:g++ -v
lu@lu-virtual-machine:~$ g++ -v
Command 'g++' not found, but can be installed with:
sudo apt install g++
按照提示安装如下:
lu@lu-virtual-machine:~$ sudo apt install g++
[sudo] password for lu:
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  g++-11 libstdc++-11-dev
Suggested packages:
  g++-multilib g++-11-multilib gcc-11-doc libstdc++-11-doc
The following NEW packages will be installed:
  g++ g++-11 libstdc++-11-dev
0 upgraded, 3 newly installed, 0 to remove and 76 not upgraded.
Need to get 13.5 MB of archives.
After this operation, 48.8 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://cn.archive.ubuntu.com/ubuntu jammy-updates/main amd64 libstdc++-11-dev amd64 11.4.0-1ubuntu1~22.04 [2,101 kB]
Get:2 http://cn.archive.ubuntu.com/ubuntu jammy-updates/main amd64 g++-11 amd64 11.4.0-1ubuntu1~22.04 [11.4 MB]
Get:3 http://cn.archive.ubuntu.com/ubuntu jammy/main amd64 g++ amd64 4:11.2.0-1ubuntu1 [1,412 B]
Fetched 13.5 MB in 6s (2,209 kB/s)
Selecting previously unselected package libstdc++-11-dev:amd64.
(Reading database ... 185262 files and directories currently installed.)
Preparing to unpack .../libstdc++-11-dev_11.4.0-1ubuntu1~22.04_amd64.deb ...
Unpacking libstdc++-11-dev:amd64 (11.4.0-1ubuntu1~22.04) ...
Selecting previously unselected package g++-11.
Preparing to unpack .../g++-11_11.4.0-1ubuntu1~22.04_amd64.deb ...
Unpacking g++-11 (11.4.0-1ubuntu1~22.04) ...
Selecting previously unselected package g++.
Preparing to unpack .../g++_4%3a11.2.0-1ubuntu1_amd64.deb ...
Unpacking g++ (4:11.2.0-1ubuntu1) ...
Setting up libstdc++-11-dev:amd64 (11.4.0-1ubuntu1~22.04) ...
Setting up g++-11 (11.4.0-1ubuntu1~22.04) ...
Setting up g++ (4:11.2.0-1ubuntu1) ...
update-alternatives: using /usr/bin/g++ to provide /usr/bin/c++ (c++) in auto mode
Processing triggers for man-db (2.10.2-1) ...
3、安装clang编译器
先判断  :  clang  -v
lu@lu-virtual-machine:~$ clang -v
Command 'clang' not found, but can be installed with:
sudo apt install clang
按照提示安装如下:
安装结束后验证如下:
Ubuntu clang version 14.0.0-1ubuntu1.1
Target: x86_64-pc-linux-gnu
Thread model: posix
InstalledDir: /usr/bin
Found candidate GCC installation: /usr/bin/../lib/gcc/x86_64-linux-gnu/11
Selected GCC installation: /usr/bin/../lib/gcc/x86_64-linux-gnu/11
Candidate multilib: .;@m64
Selected multilib: .;@m64
4、安装make
判断是否安装
lu@lu-virtual-machine:~$ make -v
Command 'make' not found, but can be installed with:
sudo apt install make        # version 4.3-4.1build1, or
sudo apt install make-guile  # version 4.3-4.1build1
按照提示安装:
lu@lu-virtual-machine:~$ sudo apt install make
Suggested packages:
  make-doc
  make
0 upgraded, 1 newly installed, 0 to remove and 75 not upgraded.
Need to get 180 kB of archives.
After this operation, 426 kB of additional disk space will be used.
Get:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu jammy/main amd64 make amd64 4.3-4.1build1 [180 kB]
Fetched 180 kB in 1s (218 kB/s)
Selecting previously unselected package make.
(Reading database ... 190541 files and directories currently installed.)
Preparing to unpack .../make_4.3-4.1build1_amd64.deb ...
Unpacking make (4.3-4.1build1) ...
Setting up make (4.3-4.1build1) ...
GNU Make 4.3
Built for x86_64-pc-linux-gnu
Copyright (C) 1988-2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
lu@lu-virtual-machine:~$ sudo apt install make-guile
  guile-3.0-libs
Suggested packages:
  make-doc
The following packages will be REMOVED:
  make
  guile-3.0-libs make-guile
0 upgraded, 2 newly installed, 1 to remove and 75 not upgraded.
Need to get 7,719 kB of archives.
After this operation, 53.3 MB of additional disk space will be used.
Get:1 http://mirrors.tuna.tsinghua.edu.cn/ubuntu jammy/universe amd64 guile-3.0-libs amd64 3.0.7-1 [7,538 kB]
Get:2 http://mirrors.tuna.tsinghua.edu.cn/ubuntu jammy/universe amd64 make-guile amd64 4.3-4.1build1 [182 kB]
Fetched 7,719 kB in 2s (4,997 kB/s)
(Reading database ... 190559 files and directories currently installed.)
Removing make (4.3-4.1build1) ...
Selecting previously unselected package guile-3.0-libs:amd64.
Preparing to unpack .../guile-3.0-libs_3.0.7-1_amd64.deb ...
Unpacking guile-3.0-libs:amd64 (3.0.7-1) ...
Selecting previously unselected package make-guile.
Preparing to unpack .../make-guile_4.3-4.1build1_amd64.deb ...
Unpacking make-guile (4.3-4.1build1) ...
Setting up guile-3.0-libs:amd64 (3.0.7-1) ...
Setting up make-guile (4.3-4.1build1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.6) ...
5、安装最新版cmake
sudo snap install cmake --classic
要等待一会儿。。。
 QT5安装
按照顺序依次安装
1、安装Qt5的组件
sudo apt-get install build-essential
 2、安装Qt的开发工具
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
3、安装qtcreator
sudo apt-get install qtcreator
 4、安装qt
sudo apt-get install qt5*
安装完毕
创建一个测试工程:
添加QLabler,运行结果如下:
到此,所有安装完成。
关键词: QT安装
2024-03-31 17:48:40     打赏
2024-03-31 17:50:38     打赏
看看
2024-03-31 19:52:01     打赏
看上去Qt的安装 还是非常方便的啊
2024-04-01 00:20:40     打赏
感谢楼主分享
2024-04-05 17:47:27     打赏
学习了,感谢楼主分享
2024-04-06 14:37:45     打赏
7楼
学习了
2024-04-06 20:04:40     打赏
8楼
2024-04-07 08:57:19     打赏
9楼
谢谢分享。学习了。
2024-04-07 10:52:39     打赏
10楼
Qt现在开启了全面收费策略。
也不知道未来会是怎么样啊
共10条 1/1 1 跳转至页
