电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » ICCVR建立工程运行有问题
ICCVR建立工程运行有问题
2024-05-15 10:28:19     打赏
代码
//ICC-AVR application builder : 2012/2/13 20:52:33
* 版权:     涛哥
* 单片机:   ATMAGE64A AU 1036
* 晶振:     外部8MHz
* 编译器:   ICC 7.22
* 文件名:   main.c
* 版本:     1.0
* 完成日期:
* 功能描述: 在8M晶振下,实现6路LED流水灯操作
#include <iom128v.h>
#include <macros.h>
#define LED PORTF
#define BEEL_ON  PORTB |= BIT(0);
#define BEEL_OFF PORTB &= ~BIT(0);
* 函数名称: delay_us()
* 入口参数: microsecond : 输入延时微秒的时间
* 出口参数:
* 功能描述: 微秒的延时
void delay_us(unsigned int microsecond)
    do
        microsecond--;
    while (microsecond>1);
* 函数名称: delay_ms()
* 入口参数: millisecond : 输入延时毫秒的时间
* 出口参数:
* 功能描述: 毫秒的延时
void delay_ms(unsigned int millisecond)
    while (millisecond--)
        delay_us(999);
void port_init(void)
 PORTA = 0x07;
 DDRA  = 0x07;
 PORTB = 0x01;
 DDRB  = 0x01;
 PORTC = 0x00; //m103 output only
 DDRC  = 0x00;
 PORTD = 0xFF;
 DDRD  = 0xFF;
 PORTE = 0x00;
 DDRE  = 0x00;
 PORTF = 0xFF;   //输入输出模式的设置!    1:为输入模式  2:为输出模式!
 DDRF  = 0xFF;   //LED口 PF2~PF7
 PORTG = 0x00;
 DDRG  = 0x00;
//call this routine to initialize all peripherals
void init_devices(void)
 //stop errant interrupts until set up
 CLI(); //disable all interrupts
 XDIV  = 0x00; //xtal divider
 XMCRA = 0x00; //external memory
 port_init();
 MCUCR = 0x00;
 EICRA = 0x00; //extended ext ints
 EICRB = 0x00; //extended ext ints
 EIMSK = 0x00;
 TIMSK = 0x00; //timer interrupt sources
 ETIMSK = 0x00; //extended timer interrupt sources
 //SEI(); //re-enable interrupts
 //all peripherals are now initialized
void main(void)
	unsigned char l;
	unsigned int k;
    	init_devices();
	BEEL_ON;
	delay_ms(100);
	BEEL_OFF;
	PORTF=0XFF;
	PORTD=0X00;
	PORTA=0X00;
    while(1)
	    PORTF= 0X00;
		delay_ms(100);
		PORTF = 0XFF;
		delay_ms(100);
原理图
可是运行只有两个灯闪。请问高手,如何解决?谢谢!
