电子产品世界 » 论坛首页 » 企业专区 » TI » 【MSP焕新大作战】课程3+任务3
【MSP焕新大作战】课程3+任务3
2024-07-04 18:00:38     打赏
说明,我目前手上没有蜂鸣器,蜂鸣器用led1点亮,熄灭代替报警功能
代码如下
#include "ti_msp_dl_config.h"
/* This results in approximately 0.5s of delay assuming 32MHz CPU_CLK */
#define DELAY (16000000)
uint8_t Disp_Dx[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x8c,0xbf,0xc6,0xa1,0x86,0xff};
uint8_t Disp_Px[8]={1,2,3,4,5,6,7,8};
uint16_t tempval =456;
uint8_t TimerCnt = 0 ;
uint16_t temp;
#define HC595_DAT(x)   ((x)?(DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_DAT_PIN)):(DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_DAT_PIN)))
#define HC595_CLK(x)   ((x)?(DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_CLK_PIN)):(DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_CLK_PIN)))
#define HC595_RCK(x)   ((x)?(DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_RCK_PIN)):(DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_RCK_PIN)))
//DS18B20 DQ 相关定义
#define DS18B20_DQ_OUTH DL_GPIO_setPins(ds18b20_PORT, ds18b20_Gpio_pin_out_PIN)
#define DS18B20_DQ_OUTL DL_GPIO_clearPins(ds18b20_PORT, ds18b20_Gpio_pin_out_PIN)
#define DS18B20_DQ_READ DL_GPIO_readPins(ds18b20_PORT, ds18b20_Gpio_pin_out_PIN)
#define DS18B20_DQ_IN DL_GPIO_initDigitalInput(ds18b20_Gpio_pin_out_IOMUX);DL_GPIO_disableOutput(ds18b20_PORT, ds18b20_Gpio_pin_out_PIN)
#define DS18B20_DQ_OUT DL_GPIO_initDigitalOutput(ds18b20_Gpio_pin_out_IOMUX);DL_GPIO_enableOutput(ds18b20_PORT, ds18b20_Gpio_pin_out_PIN)
/* 数码管相关宏定义 */
#define DigitPoint 0x7F //小数点
/* 蜂鸣器相关宏定义 */
//#define BeepON  DL_GPIO_clearPins(GPIO_BEEP_PORT, GPIO_BEEP_PIN_BEEP_PIN);
//#define BeepOFF DL_GPIO_setPins(GPIO_BEEP_PORT, GPIO_BEEP_PIN_BEEP_PIN);
#define delay_us_cycle   32
float realTemp = 0.0;
uint16_t testData = 0;
void display_out()
    HC595_RCK(0);
    delay_cycles(32);
    HC595_RCK(1);
    delay_cycles(32);
void hc595_writedata(uint8_t data)
    uint8_t i;
    for(i =0 ;i < 8; i++)
        if(data&0x80)
            HC595_DAT(1);
        else
            HC595_DAT(0);
        data <<=1;
        HC595_CLK(0);
        delay_cycles(32);
        HC595_CLK(1);
        delay_cycles(32);
void hc_send_data(uint8_t dis_num,uint8_t dis_bit)
    hc595_writedata(dis_num);
    hc595_writedata(1<<dis_bit);
    display_out();
void disp_data(uint16_t datal)
    uint16_t templ;
    uint8_t num_q,num_b,num_s,num_g;
    templ = datal;
    num_q = templ/1000;
    num_b = templ/100%10;
    num_s = templ/10%10;
    num_g = templ%10;
    hc_send_data(Disp_Dx[num_q],3);
    hc_send_data(Disp_Dx[num_b],2);
    hc_send_data(Disp_Dx[num_s],1);
    hc_send_data(Disp_Dx[num_g],0);
void Disp_Temp(float tempValue)
    uint16_t tempShow;
    uint8_t num_q, num_b, num_s,num_g;
    tempShow = tempValue;
    num_q = tempShow/1000%10;
    num_b = tempShow/100%10;
    num_s = tempShow/10%10;
    num_g = tempShow%10;
    if (num_q) {
        hc_send_data(Disp_Dx[num_q],7);
    if (num_q || num_b) {
        hc_send_data(Disp_Dx[num_b],6);
    if (num_q || num_b || num_s) {
        hc_send_data(Disp_Dx[num_s],5);
    uint8_t disData = Disp_Dx[num_g] & 0x7F; //添加小数点
    hc_send_data(disData,4);
    tempShow = (tempValue - (float)tempShow) * 10000.0;
    if (tempValue) {
    if (tempValue || num_b) {
    if (tempValue || num_b || num_s) {
void inline delay_us(uint16_t us)
    do{
        delay_cycles(delay_us_cycle);
    }while (us --);
/* 复位芯片 */
static void DS18B20_Rst(void)
    DS18B20_DQ_OUT;
    DS18B20_DQ_OUTL;    /* 拉低DQ,复位 */
    delay_us(750);      /* 拉低750us */
    DS18B20_DQ_OUTH;    /* DQ=1, 释放复位 */
    delay_us(15);       /* 延迟15US */
/* 检查总线上是否存在温度芯片 */
uint8_t DS18B20_Check(void)
  uint8_t retry = 0;
  DS18B20_DQ_IN;
  while (DS18B20_DQ_READ && retry < 200)
    retry++;
    delay_us(1);
  if (retry >= 200)
    return 1;
  else
    retry = 0;
  while (!DS18B20_DQ_READ && retry < 240)
    retry++;
    delay_us(1);
  if (retry >= 240)
    return 1;
  return 0;
/* 芯片初始化 */
uint8_t DS18B20_Init(void)
  DS18B20_Rst();
  return DS18B20_Check();
/* 读取单bit数据 */
uint8_t DS18B20_Read_Bit(void) // read one bit
  DS18B20_DQ_OUT;
  uint8_t data;
  DS18B20_DQ_OUTL;
  delay_cycles(2 * 32);
  DS18B20_DQ_OUTH;
  delay_cycles(12 * 32);
  DS18B20_DQ_IN;
  if (DS18B20_DQ_READ)
    data = 1;
  else
    data = 0;
  delay_cycles(50 * 32);
  return data;
/* 读取一字节数据 */
uint8_t DS18B20_Read_Byte(void) // read one byte
  uint8_t i, j, dat;
  dat = 0;
  for (i = 1; i <= 8; i++)
    j = DS18B20_Read_Bit();
    dat = (j << 7) | (dat >> 1);
  return dat;
/* 写入一字节数据 */
void DS18B20_Write_Byte(uint8_t dat)
  uint8_t j;
  uint8_t testb;
  DS18B20_DQ_OUT;
  for (j = 1; j <= 8; j++)
    testb = dat & 0x01;
    dat = dat >> 1;
    if (testb)
      DS18B20_DQ_OUTL; // Write 1
    //   delay_cycles(2 * 32);
      delay_us(2);
      DS18B20_DQ_OUTH;
    //   delay_cycles(60 * 32);
      delay_us(60);
    else
      DS18B20_DQ_OUTL; // Write 0
      delay_us(60);
      DS18B20_DQ_OUTH;
      delay_us(12);
/* 启动芯片 */
void DS18B20_Start(void) // ds1820 start convert
  DS18B20_Rst();
  DS18B20_Check();
  DS18B20_Write_Byte(0xcc); // skip rom
  DS18B20_Write_Byte(0x44); // convert
float DS18B20_Get_Temp(void)
  uint8_t temp;
  uint8_t TL, TH;
  int16_t tem;
  float fValue = 0.0;
  DS18B20_Start(); // ds1820 start convert
  DS18B20_Rst();
  DS18B20_Check();
  DS18B20_Write_Byte(0xbe); // convert
  TL = DS18B20_Read_Byte(); // LSB
  TH = DS18B20_Read_Byte(); // MSB
  if (TH > 7)
    TH = ~TH;
    TL = ~TL;
    temp = 0; // 温度为负
  else
    temp = 1; // 温度为正
  tem = TH;   // 获得高八位
  tem <<= 8;
  tem += TL;                // 获得底八位
  fValue = (float)tem * 0.0625; // 转换
  if (temp)
    return fValue; // 返回温度值
  else
    return -fValue;
int main(void)
    /* Power on GPIO, initialize pins as digital outputs */
    int T=123;
    SYSCFG_DL_init();
    NVIC_EnableIRQ(TIMER_0_INST_INT_IRQN);
    delay_cycles(32000);
    while (1) {
        Disp_Temp(realTemp);
void TIMER_0_INST_IRQHandler(void)
    switch(DL_TimerG_getPendingInterrupt(TIMER_0_INST))
    case DL_TIMER_IIDX_ZERO:
        TimerCnt++;
        if(TimerCnt >=100)
            TimerCnt=0;
            tempval++;
            if(tempval>500)tempval=0;
            realTemp=DS18B20_Get_Temp();
            if(realTemp>30)
                DL_GPIO_clearPins(GPIO_LEDS_PORT,GPIO_LEDS_led_PIN);
            else
                DL_GPIO_setPins(GPIO_LEDS_PORT,GPIO_LEDS_led_PIN);
        break;
    default:
        break;
视频地址
https://www.bilibili.com/video/BV1pUhHeBEL3/?vd_source=4f8f0092a0967d5a44cc4790809b35be
2024-07-05 00:13:55     打赏
谢谢分享!
