cmake ..
修改内容如下:
# Setup compiler settings set(CMAKE_C_STANDARD 11) set(CMAKE_C_STANDARD_REQUIRED ON) set(CMAKE_C_EXTENSIONS ON) set(CMAKE_MAKE_PROGRAM D:\\mingw64\\bin\\make) # Define the build type if(NOT CMAKE_BUILD_TYPE) set(CMAKE_BUILD_TYPE "Debug") endif() # Set the project name set(CMAKE_PROJECT_NAME stm32f407_demo)
如第6行添加所示
