电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » [Let'sDo第3期]DIY一个电子测光表2过程贴(测试)
共4条 1/1 1 跳转至页
2024-11-16 17:19:53     打赏
[Let'sDo第3期]    DIY一个电子测光表       2 过程贴
主板资料:
1、https://www.adafruit.com/product/5691
2、https://learn.adafruit.com/esp32-s3-reverse-tft-feather
刷固件:
从官网下载Adafruit ESP32-S3主控板固件:https://circuitpython.org/board/adafruit_feather_esp32s3_reverse_tft
测试程序:
1)呼吸灯
import board
import time
from digitalio import DigitalInOut, Direction, Pull
led = DigitalInOut(board.LED)
led.direction = Direction.OUTPUT
while True:
    led.value = True
    time.sleep(0.5)
    led.value = False
time.sleep(0.5)
2)点亮屏幕
import board
import terminalio
from adafruit_display_text import label
text = "Hello world"
text_area = label.Label(terminalio.FONT, text=text)
text_area.x = 10
text_area.y = 10
board.DISPLAY.root_group = text_area
while True:
  Pass
3)转舵机
import time
import board
import pwmio
from adafruit_motor import servo
# create a PWMOut object on Pin D5.
pwm = pwmio.PWMOut(board.D5, duty_cycle=2 ** 15, frequency=50)
# Create a servo object, my_servo.
my_servo = servo.Servo(pwm)
while True:
    for angle in range(0, 180, 1):  # 0 - 180 degrees, 5 degrees at a time.
        my_servo.angle = angle
        time.sleep(0.01)
    for angle in range(180, 0, -1): # 180 - 0 degrees, 5 degrees at a time.
        time.sleep(0.01)
4)测光照
import time
import board
import adafruit_bh1750
i2c = board.I2C()
sensor = adafruit_bh1750.BH1750(i2c)
while True:
    print("%.2f Lux"%sensor.lux)
    time.sleep(1)
GIT其他示例资料:
点灯示例
https://github.com/adafruit/Adafruit_Learning_System_Guides/blob/main/CircuitPython_Essentials/CircuitPython_Digital_In_Out/code.py
屏幕示例
https://github.com/adafruit/Adafruit_CircuitPython_Display_Text (显示库)
https://learn.adafruit.com/esp32-s3-reverse-tft-feather/displayio-example
光照示例
https://github.com/adafruit/Adafruit_CircuitPython_BH1750
舵机示例
https://github.com/adafruit/Adafruit_Learning_System_Guides/blob/main/CircuitPython_Essentials/CircuitPython_Servo/code.py
https://github.com/adafruit/Adafruit_CircuitPython_Motor  (舵机库)
关键词: 点灯     屏幕     舵机     光照
2024-11-17 00:44:30     打赏
2024-11-17 00:46:31     打赏
2024-11-17 00:49:00     打赏
共4条 1/1 1 跳转至页
