电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » [Let'sDo第3期]DIY一个电子测光表-过程帖
2024-12-01 19:46:27     打赏
接着咱们聊聊学习过程,这可是满满的干货哦~
首先呢,咱们得说说这按钮信号的获取。想象一下,你轻轻一按,ESP32-S3就能立刻知道,这是不是很神奇?其实啊,就是利用了gpio6和gpio9这两个小伙伴,它们就像是小间谍,时刻盯着按钮的动静,一旦按钮有风吹草动,它们就立刻向ESP32-S3报告!
测试代码:
import time
import adafruit_bh1750
import board
import terminalio
import displayio
import digitalio
from adafruit_display_text import label
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
button = digitalio.DigitalInOut(board.D9)
button.switch_to_input(pull=digitalio.Pull.UP)
button2 = digitalio.DigitalInOut(board.D6)
button2.switch_to_input(pull=digitalio.Pull.UP)
while True:
    if not button.value:  # 注意:当按钮被按下时,value为False(因为使用了上拉电阻)
        led.value = True
        print("button pressed")
    elif not button2.value:  # 同样,当button2被按下时,value为False
        led.value = True
        print("button1 pressed")
接下来,咱们聊聊BH1750数字光传感器这位大功臣。它的优点可不少,精度高、反应快,还能直接输出数字信号,省去了我们不少麻烦。它跟ESP32-S3之间,是通过IIC通信来传递信息的,就像是在说悄悄话一样,既快速又准确。IIC通信啊,就像是两个人之间的暗号,只要对上了,就能顺利交换信息啦!
# SPDX-FileCopyrightText: 2020 Bryan Siepert, written for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import time
import board
i2c = board.I2C()  # uses board.SCL and board.SDA
# i2c = board.STEMMA_I2C()  # For using the built-in STEMMA QT connector on a microcontroller
sensor = adafruit_bh1750.BH1750(i2c)
while True:
    print("%.2f Lux" % sensor.lux)
    time.sleep(1)
最后呢,咱们得说说这ST7789彩屏的驱动原理。这彩屏啊,就像是ESP32-S3的小脸蛋,想要它显示什么,就得靠驱动函数来帮忙。这些驱动函数啊,就像是魔术师的手,轻轻一挥,彩屏上就能出现各种各样的图案和文字啦!具体的测试代码嘛,我已经给大家准备好了,大家可以去试试哦~
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
This test will initialize the display using displayio and draw a solid green
background, a smaller purple rectangle, and some yellow text.
import board
import terminalio
import displayio
# First set some parameters used for shapes and text
BORDER = 20
FONTSCALE = 2
BACKGROUND_COLOR = 0x00FF00  # Bright Green
FOREGROUND_COLOR = 0xAA0088  # Purple
TEXT_COLOR = 0xFFFF00
display = board.DISPLAY
# Make the display context
splash = displayio.Group()
display.root_group = splash
color_bitmap = displayio.Bitmap(display.width, display.height, 1)
color_palette = displayio.Palette(1)
color_palette[0] = BACKGROUND_COLOR
bg_sprite = displayio.TileGrid(color_bitmap, pixel_shader=color_palette, x=0, y=0)
splash.append(bg_sprite)
# Draw a smaller inner rectangle
inner_bitmap = displayio.Bitmap(
    display.width - BORDER * 2, display.height - BORDER * 2, 1
inner_palette = displayio.Palette(1)
inner_palette[0] = FOREGROUND_COLOR
inner_sprite = displayio.TileGrid(
    inner_bitmap, pixel_shader=inner_palette, x=BORDER, y=BORDER
splash.append(inner_sprite)
# Draw a label
text = "Hello EEPW!"
text_area = label.Label(terminalio.FONT, text=text, color=TEXT_COLOR)
text_width = text_area.bounding_box[2] * FONTSCALE
text_group = displayio.Group(
    scale=FONTSCALE,
    x=display.width // 2 - text_width // 2,
    y=display.height // 2,
text_group.append(text_area)  # Subgroup for text scaling
splash.append(text_group)
while True:
    pass
