电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 【Mini-F5375-OB】来个小OLED时钟
2025-01-27 15:40:13     打赏
【前言】
在工程https://forum.eepw.com.cn/thread/389948/1的基础之上,添加IIC的OLED驱动,再添加RTC实现时钟的基本驱动。
【步骤】
1、选取IIC的管脚与开发板的EEPROM一致,从开发板的原理图可以看到他为PC6-SCL,PC7为SDA
2、编写IIC初始化。
我这次OLED采取了整个显存,然后用分页进行发送,因此配置为DMA发送:
void OLED_GPIO_Init(void)
	  GPIO_InitTypeDef GPIO_InitStruct;
    I2C_InitTypeDef  I2C_InitStruct;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
    I2C_DeInit(I2C1);
    I2C_StructInit(&I2C_InitStruct);
    I2C_InitStruct.I2C_Mode       = I2C_MODE_MASTER;
    I2C_InitStruct.I2C_OwnAddress = I2C_OWN_ADDRESS;
    I2C_InitStruct.I2C_ClockSpeed = 1000000;
    I2C_Init(I2C1, &I2C_InitStruct);
    I2C_TargetAddressConfig(I2C1, OLED_I2C_ADDRESS);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_4);
    GPIO_PinAFConfig(GPIOC, GPIO_PinSource7, GPIO_AF_4);
    GPIO_StructInit(&GPIO_InitStruct);
    GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
    GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_OD;
    GPIO_Init(GPIOC, &GPIO_InitStruct);
    I2C_Cmd(I2C1, ENABLE);
DMA发送函数如下:
void OLED_TxData_DMA_Polling(uint8_t *Buffer, uint8_t Length)
    DMA_InitTypeDef  DMA_InitStruct;
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    DMA_DeInit(DMA1_Channel6);
    DMA_StructInit(&DMA_InitStruct);
    DMA_InitStruct.DMA_PeripheralBaseAddr    = (uint32_t)&(I2C1->DR);
    DMA_InitStruct.DMA_MemoryBaseAddr        = (uint32_t)Buffer;
    DMA_InitStruct.DMA_DIR                   = DMA_DIR_PeripheralDST;
    DMA_InitStruct.DMA_BufferSize            = Length;
    DMA_InitStruct.DMA_PeripheralInc         = DMA_PeripheralInc_Disable;
    DMA_InitStruct.DMA_MemoryInc             = DMA_MemoryInc_Enable;
    DMA_InitStruct.DMA_PeripheralDataSize    = DMA_PeripheralDataSize_Word;
    DMA_InitStruct.DMA_MemoryDataSize        = DMA_MemoryDataSize_Byte;
    DMA_InitStruct.DMA_Mode                  = DMA_Mode_Normal;
    DMA_InitStruct.DMA_Priority              = DMA_Priority_Low;
    DMA_InitStruct.DMA_M2M                   = DMA_M2M_Disable;
    DMA_InitStruct.DMA_Auto_Reload           = DMA_Auto_Reload_Disable;
    DMA_Init(DMA1_Channel6, &DMA_InitStruct);
    I2C_DMACmd(I2C1, I2C_DMA_TXEN, ENABLE);
    DMA_Cmd(DMA1_Channel6, ENABLE);
    while (RESET == DMA_GetFlagStatus(DMA1_FLAG_TC6))
    I2C_DMACmd(I2C1, I2C_DMA_TXEN, DISABLE);
    DMA_Cmd(DMA1_Channel6, DISABLE);
发送命令,只需要发送两个字节,所以不需要采取DMA发送,函数如下:
void I2C_TxData_Polling(uint8_t *Buffer, uint8_t Length)
    uint8_t i = 0;
    for (i = 0; i < Length; i++)
        I2C_SendData(I2C1, Buffer[i]);
        while (RESET == I2C_GetFlagStatus(I2C1, I2C_STATUS_FLAG_TFE))
		I2C_GenerateSTOP(I2C1, ENABLE);
再编写发送指令与数据的两个关键函数:
  * 函    数:OLED写数据
  * 参    数:Data 要写入数据的起始地址
  * 参    数:Count 要写入数据的数量
  * 返 回 值:无
void OLED_WriteData(uint8_t *Data, uint8_t Count)
	uint8_t dat[1];
	dat[0]= 0x40;
	OLED_TxData_DMA_Polling(dat,1);
	OLED_TxData_DMA_Polling(Data,Count);
  * 函    数:OLED写命令
  * 参    数:Command 要写入的命令值,范围:0x00~0xFF
  * 返 回 值:无
void OLED_WriteCommand(uint8_t Command)
	uint8_t commadDat[2];
	commadDat[0] = 0x00;
	commadDat[1] = Command;
	I2C_TxData_Polling(commadDat, 2);
到此IIC的移植就可以了。
【RTC移植】
复制官方示例到工程之中,在mm32f5370_it.c中添加中断回调函数:
void RTC_IRQHandler(void)
  if (RTC_GetITStatus(RTC_IT_SEC) != RESET)
    RTC_UpdateCalendar();
    RTC_ClearITPendingBit(RTC_IT_SEC);
    RTC_WaitForLastTask();
在main.c中添加OLED显示任务:
void led1_task(void *pvParameters)
    while(1)
        OLED_Printf(0,16,OLED_8X16,"%02d:%02d:%02d", RTC_Calendar.hour,RTC_Calendar.minute,RTC_Calendar.second);
        OLED_Update();
        GPIO_WriteBit(GPIOB, GPIO_Pin_15, 0);
        vTaskDelay(500);
        GPIO_WriteBit(GPIOB, GPIO_Pin_15, 1);
        vTaskDelay(500);
实现效果:
下载到开发板后,就可以看到实时运行的时钟了。
关键词: Mini-F5375-OB     灵动MM32     OLED
