06 树莓派5 DHT11
开始是打算通过python实现这一部分功能的,但是发现各种方式都无法实现,最终采用wiringPi+c的方式实现了,树莓派5是不支持wiringPi库的,需要自己编译安装。
#源地址 #https://github.com/WiringPi/WiringPi git clone https://gitee.com/dnspeak/WiringPi.git cd WiringPi sudo build.sh
正确接线:
DHT11 VCC → 树莓派3.3V(物理引脚1或17)
DATA → GPIO4(如GPIO4,物理引脚7)
GND → 树莓派GND(物理引脚6/9/14等)
二,代码部分
#include <wiringPi.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#include <unistd.h>
#include <jansson.h>
#define MAX_TIMINGS 85
#define DHT_PIN 7 // GPIO7 (BCM编号)
#define UDP_PORT 10002
#define TARGET_IP "127.0.0.1" // 目标IP地址
int data[5] = {0, 0, 0, 0, 0};
int sockfd;
struct sockaddr_in servaddr;
// 初始化UDP套接字
void init_udp() {
if ((sockfd = socket(AF_INET, SOCK_DGRAM, 0)) < 0) {
perror("socket创建失败");
exit(EXIT_FAILURE);
memset(&servaddr, 0, sizeof(servaddr));
servaddr.sin_family = AF_INET;
servaddr.sin_port = htons(UDP_PORT);
servaddr.sin_addr.s_addr = inet_addr(TARGET_IP);
// 发送JSON格式数据
void send_data(float humidity, float temperature) {
json_t *root = json_object();
json_object_set_new(root, "sensor", json_string("DHT11"));
json_object_set_new(root, "humidity", json_real(humidity));
json_object_set_new(root, "temperature", json_real(temperature));
char *json_str = json_dumps(root, JSON_COMPACT);
sendto(sockfd, json_str, strlen(json_str), 0,
(const struct sockaddr *)&servaddr, sizeof(servaddr));
free(json_str);
json_decref(root);
// 读取DHT11传感器数据
void read_dht_data() {
uint8_t laststate = HIGH;
uint8_t counter = 0;
uint8_t j = 0, i;
float fah, cel;
data[0] = data[1] = data[2] = data[3] = data[4] = 0;
pinMode(DHT_PIN, OUTPUT);
digitalWrite(DHT_PIN, LOW);
delay(18);
digitalWrite(DHT_PIN, HIGH);
delayMicroseconds(40);
pinMode(DHT_PIN, INPUT);
for (i = 0; i < MAX_TIMINGS; i++) {
counter = 0;
while (digitalRead(DHT_PIN) == laststate) {
counter++;
delayMicroseconds(1);
if (counter == 255) break;
laststate = digitalRead(DHT_PIN);
if ((i >= 4) && (i % 2 == 0)) {
data[j/8] <<= 1;
if (counter > 16) data[j/8] |= 1;
j++;
if ((j >= 40) &&
(data[4] == ((data[0] + data[1] + data[2] + data[3]) & 0xFF))) {
cel = data[2] + (data[3] / 10.0);
fah = cel * 1.8f + 32;
printf("湿度 = %d.%d %% 温度 = %d.%d *C (%.1f *F)\n",
data[0], data[1], data[2], data[3], fah);
send_data((float)data[0] + data[1]/10.0, cel);
} else {
printf("数据校验失败! (接收 %d 位)\n", j);
int main() {
printf("Raspberry Pi DHT11 温度湿度测试\n");
if (wiringPiSetup() == -1) {
fprintf(stderr, "wiringPi初始化失败!\n");
return 1;
init_udp();
while (1) {
read_dht_data();
delay(1000); // 每1秒读取一次
close(sockfd);
return 0;
}编译
gcc -o dht11_udp dht11_udp.c -lwiringPi -ljansson
运行
sudo ./dht11_udp
测试
#安装netcat-openbsd sudo apt update sudo apt install netcat-openbsd #端口监听 nc -u -l -p 10002
运行及测试结果
Qt部分只需要在上期的基础上添加一个DHT11的ipc对象,还有一个DHT11的信号,用于触发温湿度仪表的显示。
成果演示
