电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 【转载】STM32F407和K230串口通信--from毅
2025-10-20 23:23:20     打赏
STM32F407串口配置:配置串口PA9/PA10
void uart_init(u32 bound){
   //GPIO端口设置
  GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //使能GPIOA时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);//使能USART1时钟
//串口1对应引脚复用映射
GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1); //GPIOA9复用为USART1
GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1); //GPIOA10复用为USART1
//USART1端口配置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10; //GPIOA9与GPIOA10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //速度50MHz
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA9,PA10
   //USART1 初始化设置
USART_InitStructure.USART_BaudRate = bound;//波特率设置
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
  USART_Init(USART1, &USART_InitStructure); //初始化串口1
  USART_Cmd(USART1, ENABLE);  //使能串口1
//USART_ClearFlag(USART1, USART_FLAG_TC);
#if EN_USART1_RX
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启相关中断
//Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;//串口1中断通道
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3
NVIC_InitStructure.NVIC_IRQChannelSubPriority =3; //子优先级3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
NVIC_Init(&NVIC_InitStructure); //根据指定的参数初始化VIC寄存器、
#endif
void USART1_IRQHandler(void)                //串口1中断服务程序
u8 Res;
#if SYSTEM_SUPPORT_OS //如果SYSTEM_SUPPORT_OS为真,则需要支持OS.
OSIntEnter();
#endif
if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)  //接收中断(接收到的数据必须是0x0d 0x0a结尾)
Res =USART_ReceiveData(USART1);//(USART1->DR); //读取接收到的数据
if((USART_RX_STA&0x8000)==0)//接收未完成
if(USART_RX_STA&0x4000)//接收到了0x0d
if(Res!=0x0a)USART_RX_STA=0;//接收错误,重新开始
else USART_RX_STA|=0x8000; //接收完成了
else //还没收到0X0D
if(Res==0x0d)USART_RX_STA|=0x4000;
else
USART_RX_BUF[USART_RX_STA&0X3FFF]=Res ;
USART_RX_STA++;
if(USART_RX_STA>(USART_REC_LEN-1))USART_RX_STA=0;//接收数据错误,重新开始接收
主函数:接收K230发送的数据并做应答:接收K230发送的一个数组,并且闪烁LED
#include "sys.h"
#include "usart.h"
#include "delay.h"
#include "led.h"
#include "oled.h"
#include "string.h"
extern uint8_t USART_RX_BUF[USART_REC_LEN];
extern uint16_t USART_RX_STA;
char displayStr[32];
uint16_t i,len;
void Send_To_K230(uint8_t *data, uint16_t len) {
    for( i = 0; i < len; i++) {
        USART_SendData(USART1, data[i]);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
int main(void) {
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    delay_init(168);
    uart_init(115200);
    LED_Init();
    OLED_Init();
    OLED_Clear();
    OLED_ShowString(0, 0, "UART Receiver", 16);
    OLED_ShowString(0, 16, "Waiting...", 16);
    OLED_Refresh_Gram();
    while(1) {
        if(USART_RX_STA & 0x8000) {
             len = USART_RX_STA & 0x3FFF;
            // 检查是否收到特定数组 [25,10,10]
            if(len >= 3 &&
               USART_RX_BUF[0] == 25 &&
               USART_RX_BUF[1] == 10 &&
               USART_RX_BUF[2] == 10) {
                LED0 = !LED0; // 翻转LED
                // 在OLED上显示接收到的数组
                sprintf(displayStr, "RX: %d,%d,%d",
                        USART_RX_BUF[0],
                        USART_RX_BUF[1],
                        USART_RX_BUF[2]);
                OLED_ShowString(0, 16, displayStr, 16);
                // 发送确认信息回K230
                Send_To_K230((uint8_t*)"ACK: Array Received\r\n", 22);
                // 在OLED上显示已响应
                OLED_ShowString(0, 32, "Sent ACK to K230", 16);
            } else {
                // 显示接收到的原始数据
                char infoStr[32];
                sprintf(infoStr, "RX Len: %d", len);
                OLED_ShowString(0, 16, infoStr, 16);
                // 显示前3个字节
                if(len > 0) {
                    sprintf(infoStr, "Data: %d,%d,%d",
                            USART_RX_BUF[0],
                            len > 1 ? USART_RX_BUF[1] : 0,
                            len > 2 ? USART_RX_BUF[2] : 0);
                    OLED_ShowString(0, 32, infoStr, 16);
            USART_RX_STA = 0;  // 清除接收标志
        delay_ms(10);
K230的配置就较为简单了,这里直接给出代码,可根据自己需求更改。
from machine import UART
from machine import FPIOA
import time
import machine
fpioa = FPIOA()
fpioa.set_function(11, FPIOA.UART2_TXD)
fpioa.set_function(12, FPIOA.UART2_RXD)
uart = UART(UART.UART2, 115200)  # 设置串口号2和波特率
data_array = [25,10,10]  # ASCII: H e l l o
while True:
    uart.write(bytes(data_array))  # 将列表转为字节对象发送
    uart.write('\r\n')  # 添加换行便于观察
    text = uart.read(128)  # 接收128个字符
    if text != None:
        print(text)  # 通过REPL打印串口接收的数据
    time.sleep(0.1)  # 100ms
K230把数组data_array发送给32F407,32接收到数组后闪烁LED并发送"   Array Received "表明接收成功。
STM32识别为特定命令
当STM32检测到此数组时:
翻转LED状态
OLED显示接收到的数组值
向K230发送确认信息 "ACK: Array Received"
OLED显示"Sent ACK to K230"
对于其他数据:
显示接收数据长度
显示前3个字节的十进制值
K230和STM32就能通过字节数组进行通信了,K230发送的 bytes([25,10,10]) 会被STM32识别并响应。
来源: 整理文章为传播相关技术,网络版权归原作者所有,如有侵权,请联系删除。
