电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 硬件I2C查询模式读写EEPROM
硬件I2C查询模式读写EEPROM
2025-12-20 14:27:32     打赏
看了几天的datasheet,准备完成硬件I2C操作。现在先实现查询方式读取与写入。
硬件上面EEPROM使用AT24C02国产兼容芯片,地址为0xA0(8bit),I2C外设为I2C2,引脚为PF6,PF7。
我实现的示例是在地址0x00处写入'hello"字符串,并回读预期应为"hello"。实验测试通过
 * @brief:  I2C2,
 *          PF6 AF0 SCK,
 *          PF7 AF0 SDA,
 * @param:
 * @return:
 * @note:
void i2c_init(void)
  GPIO_Config_T gpioConfigStruct;
  I2C_Config_T i2cConfigStruct;
  /* Enable I2C related Clock */
  RCM_EnableAHBPeriphClock(RCM_AHB_PERIPH_GPIOF);
  RCM_EnableAPB1PeriphClock(RCM_APB1_PERIPH_I2C2);
  RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_SYSCFG);
  /* Free I2C_SCL and I2C_SDA */
  gpioConfigStruct.mode = GPIO_MODE_OUT;
  gpioConfigStruct.speed = GPIO_SPEED_2MHz;
  gpioConfigStruct.outtype = GPIO_OUT_TYPE_PP;
  gpioConfigStruct.pupd = GPIO_PUPD_NO;
  gpioConfigStruct.pin = GPIO_PIN_6;
  GPIO_Config(GPIOF, &gpioConfigStruct);
  gpioConfigStruct.pin = GPIO_PIN_7;
  GPIO_SetBit(GPIOF, GPIO_PIN_6);
  GPIO_SetBit(GPIOF, GPIO_PIN_7);
  /* Connect I2C to SCL */
  GPIO_ConfigPinAF(GPIOF, GPIO_PIN_SOURCE_6, GPIO_AF_PIN0);
  /* Connect I2C to SDA */
  GPIO_ConfigPinAF(GPIOF, GPIO_PIN_SOURCE_7, GPIO_AF_PIN0);
  /*  Config I2C1 GPIO */
  gpioConfigStruct.mode = GPIO_MODE_AF;
  gpioConfigStruct.outtype = GPIO_OUT_TYPE_OD;
  /* Config I2C2 */
  I2C_Reset(I2C2);
  i2cConfigStruct.ack = I2C_ACK_ENABLE;
  i2cConfigStruct.ackaddress = I2C_ACK_ADDRESS_7BIT;
  i2cConfigStruct.address1 = 0x52;
  i2cConfigStruct.analogfilter = I2C_ANALOG_FILTER_ENABLE;
  i2cConfigStruct.digitalfilter = I2C_DIGITAL_FILTER_0;
  i2cConfigStruct.mode = I2C_MODE_I2C;
  i2cConfigStruct.timing = 0xB0420F13;
  I2C_Config(I2C2, &i2cConfigStruct);
  /* Enable I2Cx */
  I2C_Enable(I2C2);
int i2c_send(uint8_t dev_addr, uint8_t *buf, uint16_t len)
  int ret = 0;
  uint16_t i;
  while (I2C_ReadStatusFlag(I2C2, I2C_FLAG_BUSY) == SET)
  I2C_HandlingTransfer(I2C2, dev_addr, len, I2C_RELOAD_MODE_AUTOEND, I2C_GENERATE_START_WRITE);
  for (i = 0; i < len; i++)
    I2C_TxData(I2C2, buf[i]);
    while (I2C_ReadStatusFlag(I2C2, I2C_FLAG_TXBE) == RESET)
  I2C_EnableGenerateStop(I2C2);
  while (I2C_ReadStatusFlag(I2C2, I2C_FLAG_STOP) == RESET)
  return (ret);
int i2c_receive(uint8_t dev_addr, uint8_t *buf, uint16_t len)
  int ret = 0;
  uint16_t i;
  I2C_HandlingTransfer(I2C2, dev_addr, len, I2C_RELOAD_MODE_AUTOEND, I2C_GENERATE_START_READ);
    while (I2C_ReadStatusFlag(I2C2, I2C_FLAG_RXBNE) == RESET)
    buf[i] = (uint8_t)I2C_RxData(I2C2);
  return (ret);
int i2c_xfer(uint8_t dev_addr, uint16_t reg_addr, uint8_t reg_len, uint8_t *buf, uint16_t len)
  int ret = 0;
  uint16_t i;
  I2C_HandlingTransfer(I2C2, dev_addr, reg_len, I2C_RELOAD_MODE_SOFTEND, I2C_GENERATE_START_WRITE);
  if (reg_len == 1)
    I2C_TxData(I2C2, (uint8_t)(reg_addr & 0x00FF));
  else if (reg_len == 2)
  else
    /* something wrong */
  return (ret);
关键词: EEPROM     查询     硬件
2025-12-22 17:06:32     打赏
谢谢分享,学习了并给你点赞。
