【前言】
Zephyr已经支持STM32H747的官方开发板。本篇将分享如何快速体验驱动LCD屏。
【开发环境】
1、wsl2
2、west
【实现步骤】
1、复制hello world工程
cp -r ~/zephyrproject\zephyr\samples\drivers\display ~/zephyrproject/app/stm32h747/H747_display
2、加载虚拟环境:
~/zephyrproject/app/stm32h747/hello_world$ source ~/zephyrproject/zephyr/zephyr-env.sh
3、进入lcd工程
lugl@lugl:~/zephyrproject/app/stm32h747/h747_display$ ls CMakeLists.txt README.rst boards build prj.conf src
4、在stm32h747的网页中,如果使用lcd屏,必须指定设备树:
经查看屏的型号为MB1166-A09,因此在编译时需要指定参数如下:
--shield st_b_lcd40_dsi1_mb1166_a09
5、程序修改
由于例程用到了malloc,然而好象现在版本的不支持动态申请内存,因此我指定一个内存给buf
#define DISPLAY_BUFFER_SIZE (384U * 1024U) /* 384 KB */ static uint8_t __aligned(4) display_buffer[DISPLAY_BUFFER_SIZE];
6、编译
west build -p auto -b stm32h747i_disco/stm32h747xx/m7 --shield st_b_lcd40_dsi1_mb1166_a09 [9/9] Linking C executable zephyr/zephyr.elf Memory region Used Size Region Size %age Used FLASH: 42264 B 1 MB 4.03% RAM: 465984 B 512 KB 88.88% EXTMEM: 0 GB 64 MB 0.00% SRAM0: 0 GB 512 KB 0.00% SRAM1: 0 GB 128 KB 0.00% SRAM2: 0 GB 128 KB 0.00% SRAM3: 16 KB 32 KB 50.00% SRAM4: 0 GB 64 KB 0.00% SDRAM2: 1500 KB 32 MB 4.58% IDT_LIST: 0 GB 32 KB 0.00% Generating files from /home/lugl/zephyrproject/app/stm32h747/h747_display/build/zephyr/zephyr.elf for board: stm32h747i_disco
7、下载
加载st-link到wsl中
PS C:WINDOWSsystem32> usbipd attach --wsl --busid 2-2 usbipd: info: Using WSL distribution 'Ubuntu-22.04' to attach; the device will be available in all WSL 2 distributions. usbipd: info: Detected networking mode 'nat'. usbipd: info: Using IP address 172.29.112.1 to reach the host.
然后执行下载:
lugl@lugl:~/zephyrproject/app/stm32h747/blinky$ west flash --runner openocd -- west flash: rebuilding ninja: no work to do. -- west flash: using runner openocd -- runners.openocd: Flashing file: /home/lugl/zephyrproject/app/stm32h747/blinky/build/zephyr/zephyr.hex Open On-Chip Debugger 0.11.0 Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html init Info : STLINK V3J16M8 (API v3) VID:PID 0483:374E Info : Target voltage: 3.283124 Info : Unable to match requested speed 1800 kHz, using 1000 kHz Info : Unable to match requested speed 1800 kHz, using 1000 kHz Info : clock speed 1000 kHz Info : stlink_dap_op_connect(connect) Info : SWD DPIDR 0x6ba02477 Info : stm32h7x.cpu0: hardware has 8 breakpoints, 4 watchpoints Info : stm32h7x.cpu0: external reset detected Info : starting gdb server for stm32h7x.cpu0 on 3333 Info : Listening on port 3333 for gdb connections target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x08000c58 msp: 0x240011c0 TargetName Type Endian TapName State -- ------------------ ---------- ------ ------------------ ------------ 0 stm32h7x.ap2 mem_ap little stm32h7x.cpu halted 1* stm32h7x.cpu0 cortex_m little stm32h7x.cpu halted target halted due to debug-request, current mode: Thread xPSR: 0x01000000 pc: 0x08000c58 msp: 0x240011c0 Info : Unable to match requested speed 4000 kHz, using 3300 kHz Info : Unable to match requested speed 4000 kHz, using 3300 kHz Info : Device: STM32H74x/75x Info : flash size probed value 2048 Info : STM32H7 flash has dual banks Info : Bank (0) size is 1024 kb, base address is 0x08000000 Warn : Adding extra erase range, 0x08004ec0 .. 0x0801ffff auto erase enabled wrote 20160 bytes from file /home/lugl/zephyrproject/app/stm32h747/blinky/build/zephyr/zephyr.hex in 4.200407s (4.687 KiB/s) Error: stm32h7x.cpu0 -- clearing lockup after double fault target halted due to debug-request, current mode: Handler Reset xPSR: 0xa05f0001 pc: 0xa05f0001 msp: 0xa05f0001 Polling target stm32h7x.cpu0 failed, trying to reexamine Info : stm32h7x.cpu0: hardware has 0 breakpoints, 10 watchpoints Info : stm32h7x.cpu0: external reset detected shutdown command invoked
屏已经顺利点亮:
【总结】
stm32H747已经完美的适配好zephyr生态,可以非常快速的创建开发环境。点亮LCD屏也相当容易。
