人生苦短,python大法好。官网已经支持这款板卡了,https://micropython.org/download/ARDUINO_GIGA/
按照教程下载dfu固件和dfu-util工具,使用命令即可烧写
dfu-util -w -a 0 -d 2341:035b -D ARDUINO_GIGA-20251209-v1.27.0.dfu
测试代码
# main.py -- put your code here!
import machine
from machine import Pin
from machine import Timer
import time
import network
machine.freq()
print(machine.freq())
def do_connect():
wlan = network.WLAN(network.WLAN.IF_STA)
wlan.active(True)
if not wlan.isconnected():
print('connecting to network...')
wlan.connect('ssid', 'pwd')
while not wlan.isconnected():
pass
print('network config:', wlan.ipconfig('addr4'))
do_connect()
p0 = Pin('PE3', Pin.OUT)
while True:
p0.value(1)
time.sleep(1)
p0.value(0)
time.sleep(1)打印消息如下
