电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 【雅特力Zephyr】1、VSCode配置AT32F423指南
2026-02-28 21:41:19   被打赏 20 分(兑奖)     打赏
【前言】
最近调通了gd32f527的Zephyr工程,然后国产的雅特力还没有人接手做Zephyr的移植,我准备把手上的开发板利用起来,给国产的芯片移植到Zephyr生态贡献一份力量。
要移植Zephyr,那么首先需要整理好在vscode下面开发板的基础工作。雅特力刚好提供了vscode的模工程,此次是下载官方的vscode模版库,然后完成配置,实现在vscode下面的开发、下载、调试等工作。
1. 准备工作
首先下载官方的AN0130_AT32_MCU_Develop_With_VSCode_V2.0.5.zip库,这个库我上传到附件。
解压后,使用vscode打开at32f423的模版库
工具链目录结构
D:\AT32F423\SourceCode\software_tool\tool_for_windows\
├── OpenOCD_V2.0.2\           # OpenOCD 调试器
│   ├── bin\openocd.exe
│   └── scripts\
│       ├── interface\atlink.cfg
│       └── target\at32f423xx.cfg
└── gcc-arm-none-eabi-10.3-2021.10-win32.exe
C:\Users\liujianhua\.eide\tools\gcc_arm\bin\
└── arm-none-eabi-gcc.exe     # GCC 编译工具链
修改配置如下:
 2. .vscode/launch.json
    "configurations": [
            "cwd": "${workspaceRoot}",
            "type": "cortex-debug",
            "request": "launch",
            "name": "openocd-launch",
            "armToolchainPath": "C:/Users/liujianhua/.eide/tools/gcc_arm/bin",
            "gdbPath": "C:/Users/liujianhua/.eide/tools/gcc_arm/bin/arm-none-eabi-gdb.exe",
            "interface": "swd",
            "servertype": "openocd",
            "serverpath": "D:/AT32F423/SourceCode/software_tool/tool_for_windows/OpenOCD_V2.0.2/bin/openocd.exe",
            "configFiles": [
                "D:/AT32F423/SourceCode/software_tool/tool_for_windows/OpenOCD_V2.0.2/scripts/interface/atlink.cfg",
                "D:/AT32F423/SourceCode/software_tool/tool_for_windows/OpenOCD_V2.0.2/scripts/target/at32f423xx.cfg"
            "executable": "build/at32f423_template.elf",
            "svdFile": "project/misc/AT32F423xx_v2.svd",
            "runToEntryPoint": "main"
3. .vscode/tasks.json
    "version": "2.0.0",
    "tasks": [
            "label": "build",
            "type": "shell",
            "command": "make",
            "args": ["-j4"],
            "problemMatcher": []
            "label": "clean",
            "type": "shell",
            "command": "make",
            "args": ["clean"],
            "label": "download code",
            "type": "process",
            "command": "D:/AT32F423/SourceCode/software_tool/tool_for_windows/OpenOCD_V2.0.2/bin/openocd.exe",
            "args": [
                "-f", "D:/AT32F423/SourceCode/software_tool/tool_for_windows/OpenOCD_V2.0.2/scripts/interface/atlink.cfg",
                "-f", "D:/AT32F423/SourceCode/software_tool/tool_for_windows/OpenOCD_V2.0.2/scripts/target/at32f423xx.cfg",
                "-c", "program build/at32f423_template.hex",
                "-c", "exit"
4. .vscode/c_cpp_properties.json
    "configurations": [
            "name": "Win32",
            "includePath": [
                "C:/Users/liujianhua/.eide/tools/gcc_arm/arm-none-eabi/include",
                "${workspaceFolder}/project/inc",
                "${workspaceFolder}/project/board",
                "${workspaceFolder}/libraries/cmsis/cm4/core_support",
                "${workspaceFolder}/libraries/cmsis/cm4/device_support",
                "${workspaceFolder}/libraries/drivers/inc",
                "${workspaceFolder}",
            "defines": [
                "_DEBUG", "UNICODE", "_UNICODE",
                "AT_START_F423_V1",
                "AT32F423VCT7",
                "USE_STDPERIPH_DRIVER"
            "compilerPath": "C:/Users/liujianhua/.eide/tools/gcc_arm/bin/arm-none-eabi-gcc.exe",
            "cStandard": "gnu17",
            "cppStandard": "gnu++14",
            "intelliSenseMode": "gcc-x64"
    "version": 4
5. 关键注意事项
坑点1:OpenOCD 版本必须使用 `D:\AT32F423\SourceCode\software_tool\tool_for_windows\OpenOCD_V2.0.2\bin\openocd.exe`系统自带的 `C:\OpenOCD\bin\openocd.exe` 缺少 `at32f4xx` Flash 驱动,会报错:  Error: flash driver 'at32f4xx' not found
 坑点2:调试 vs 下载路径不同调试 (launch.json): 需要加 `serverpath` 指定 OpenOCD 路径下载 (tasks.json): 需要在 `command` 中写完整路径
 坑点3:VSCode 默认使用 PATH 中的 openocdCortex-Debug 扩展默认从系统 PATH 查找 openocd必须在 launch.json 中显式指定 `serverpath`
6. 硬件连接
| AT-LINK | AT32F423 ||---------|----------|| SWDIO   | PA13     || SWCLK   | PA14     || VCC     | VCC      || GND     | GND      |
7. 验证方法
1. 编译: Ctrl+Shift+P → "Tasks: Run Task" → "build"2. 下载: Ctrl+Shift+P → "Tasks: Run Task" → "download code"
3. 调试: F5 或点击调试按钮
附:工程模板
at32f423.zip
关键词: AT32F423     VSCode     Zephyr
2026-03-03 10:31:34     打赏
这个最后走的还是Cmake吧
