电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 状态机实现的按键扫描
状态机实现的按键扫描
2026-09-15 21:29:34     打赏
按键的实现方案挺多,本次先尝试一下按键扫描。
硬件上按键采用按下时对GND短接,故需要配置GPIO引脚为内置上拉电阻,以稳定空闲按键电平。硬件原理图如下:
软件的按键初始化与检测代码如下:
void bsp_gpio_init(void)
  GPIO_Config_T gpioConfig;
  gpioConfig.speed = GPIO_SPEED_2MHz;
  gpioConfig.mode = GPIO_MODE_IN;
  gpioConfig.pupd = GPIO_PUPD_PU;
  gpioConfig.pin = GPIO_PIN_0;
  GPIO_Config(GPIOA, &gpioConfig);
  gpioConfig.pin = GPIO_PIN_1;
static inline int keybutton_ispressd(key_id_t key_id)
  int ret = 0;
  switch (key_id)
  case key_id_0:
    ret = GPIO_ReadInputBit(GPIOA, GPIO_PIN_0);
    break;
  case key_id_1:
    ret = GPIO_ReadInputBit(GPIOA, GPIO_PIN_1);
    break;
  if(ret == 0)
    return (1);
  else
    return (0);
由于采用轮询方式回读GPIO状态,所以,我们必须添加软件去抖的算法。我这里和其它实现方案一样,也是采用状态机实现方式。简单说,两次采样一致则认为状态稳定。我定义Key的状态如下:
typedef enum
  kb_state_initial = 0,
  kb_state_idle,
  kb_state_down,
  kb_state_down2,
  kb_state_up,
  kb_state_up2
} kb_state_t;
按键的状态轮转图如下图所示:
本次代码还是蛮多的,于是先写了一段测试代码:
int main(void)
  int ret = 0;
  bsp_init();
  SysTick_Config(SystemCoreClock / 1000);
  while (1)
    ret = keybutton_ispressd(key_id_0);
    reg_zone[0] = ret;
    ret = keybutton_ispressd(key_id_1);
    reg_zone[1] = ret;
当我按下按键时,可以看到reg_zone[0]=1。这也验证了我的GPIO输入引脚工作正常。
第一阶段已经验证完毕,我们赶紧实现状态机的代码。
void keybutton_init(void)
  key_inst[0].id = key_id_0;
  key_inst[0].event = kb_event_null;
  key_inst[0].state = kb_state_idle;
  key_inst[1].id = key_id_1;
  key_inst[1].event = kb_event_null;
  key_inst[1].state = kb_state_idle;
void keybutton_scan(key_class_t *kb)
  int ret = 0;
  switch (kb->state)
  case kb_state_idle:
    ret = keybutton_ispressd(kb->id);
    if (ret != 0)
      kb->state = kb_state_down;
    break;
  case kb_state_down:
    if (ret != 0)
      kb->state = kb_state_down2;
    else
      kb->state = kb_state_idle;
    break;
  case kb_state_down2:
    if (ret == 0)
      kb->state = kb_state_up;
    break;
  case kb_state_up:
    if (ret == 0)
      kb->state = kb_state_up2;
    else
    break;
  case kb_state_up2:
    if (ret == 0)
      kb->event = kb_event_click;
    else
    break;
实现了一下,效果还是不错的。
关键词: 状态机     按键     扫描
2026-09-16 00:31:48     打赏
感觉就是一个连消抖都不稳定的实现。我的理解,做成两层状态机可能更合适,最底层就是最简单的按键的按下松开判断,然后上面一层就是根据是否按下的计时时长去切换状态,并抛出相应的按键事件在上层的应用处理
