电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 继续把玩ESP32-S3ReverseTFTFeatherbyAdafruit(
继续把玩ESP32-S3ReverseTFTFeatherbyAdafruit(二)
2026-10-09 22:14:02     打赏
接上次的帖子,
https://forum.eepw.com.cn/thread/401710/1
要做一个数据显示的界面,需要折线滑动效果,有界面显示标题,
简单配置后,效果如下:
import board
import displayio
import math
import time
import terminalio
from adafruit_display_text import label
display = board.DISPLAY
WIDTH = display.width    # 240
HEIGHT = display.height  # 135
# ========== 画布 ==========
group = displayio.Group()
bitmap = displayio.Bitmap(WIDTH, HEIGHT, 2)
palette = displayio.Palette(2)
palette[0] = 0x000000   # 背景(黑)
palette[1] = 0x00FF00   # 波形(绿)
tile = displayio.TileGrid(bitmap, pixel_shader=palette)
group.append(tile)
# ========== 添加文字标签 "HI EEPW!" ==========
text = "HI EEPW!"
text_label = label.Label(terminalio.FONT, text=text, color=0xFFFFFF)  # 白色文字
# 居中显示在屏幕上方
text_label.anchored_position = (WIDTH // 2, 20)
text_label.anchor_point = (0.9, 0.9)
group.append(text_label)
display.root_group = group
# ========== 参数 ==========
amplitude = 10
center_y = HEIGHT // 2
step = 0.3        # 每列相位步进
phase = 0.0
SHIFT = 1         # 每帧左移列数
DRAW = 1          # 每帧在最右端补画的点数(越大越密)
while True:
    # 1) 整屏向左平移 SHIFT 列(丢弃最左的 SHIFT 列)
    for x in range(WIDTH - SHIFT):
        for y in range(HEIGHT):
            bitmap[x, y] = bitmap[x + SHIFT, y]
    # 2) 清空最右端 DRAW 列(避免残留)
    for x in range(WIDTH - DRAW, WIDTH):
            bitmap[x, y] = 0
    # 3) 在右侧补画 DRAW 个连续点,形成较密的波
    for k in range(DRAW):
        x = WIDTH - DRAW + k
        yy = int(center_y - amplitude * math.sin(phase + x * step))
        yy = max(0, min(HEIGHT - 1, yy))
        bitmap[x, yy] = 1
    phase += step * SHIFT
    display.refresh()
    time.sleep(0.005)
关键词: 继续     把玩     ESP32-S3ReverseTFTF
