接上次的帖子,
https://forum.eepw.com.cn/thread/401710/1
闲来无事,先做个三行的数据动态显示
简单配置后,效果如下:
import board import displayio import time import rtc import random import terminalio from adafruit_display_text import label display = board.DISPLAY WIDTH = display.width # 240 HEIGHT = display.height # 135 # ========== 设置 RTC 时间(手动,可改成你的当前时间) ========== rtc.RTC().datetime = time.struct_time((2026, 10, 9, 22, 45, 0, 4, -1, -1)) # ========== 画布(纯背景) ========== group = displayio.Group() bitmap = displayio.Bitmap(WIDTH, HEIGHT, 1) palette = displayio.Palette(1) palette[0] = 0x000000 # 背景(黑) tile = displayio.TileGrid(bitmap, pixel_shader=palette) group.append(tile) text_label1 = label.Label( terminalio.FONT, text="test result" , color=0x00ff00, scale=2, ) #text_label1.anchor_point = (0.5, 0.5) text_label1.anchored_position = (60, 10) text_label1.anchor_point = (0.0, 0.0) group.append(text_label1) # ========== 第一行:HI EEPW! + 计数 ========== counter = 0.01 text_label1 = label.Label( terminalio.FONT, text="HI EEPW! %.2f" % counter, color=0x00ff00, scale=2, ) text_label1.anchored_position = (10, 40) text_label1.anchor_point = (0.0, 0.0) group.append(text_label1) # ========== 第二行:时间 ========== time_label = label.Label( terminalio.FONT, text="", color=0xFFFF00, # 黄色 scale=2, ) time_label.anchored_position = (10, 75) time_label.anchor_point = (0.0, 0.0) group.append(time_label) # ========== 第三行:10 个随机两位小数,随机显示其中一个 ========== # 生成包含 10 个随机两位小数的数组 num_array = [round(random.uniform(0, 100), 2) for _ in range(10)] z_label = label.Label( terminalio.FONT, text="", color=0x00FFFF, # 青色,可自行改色 scale=2, ) z_label.anchored_position = (10, 110) z_label.anchor_point = (0.0, 0.0) group.append(z_label) def update_z(): """从数组中随机取一个数,前面加 Z: 显示""" z_label.text = "Z: %.2f" % random.choice(num_array) # 首次显示 update_z() display.root_group = group # ========== 数值计时 ========== last_count_time = time.monotonic() last_second = -1 while True: now = time.monotonic() # 1) 每秒计数 +1 if now - last_count_time >= 1.0: counter += 1 last_count_time = now text_label1.text = "X:%.2f" % counter # 2) 每秒刷新时间 t = time.localtime() if t.tm_sec != last_second: last_second = t.tm_sec time_label.text = "TIME:%02d:%02d:%02d" % (t.tm_hour, t.tm_min, t.tm_sec) update_z() display.refresh() time.sleep(0.01)
效果为数字1s变换一次,这个时间是开机固定写入。这个应该是连接wifi,连接一个ntp服务器获取时间比较准。下一篇完成wifi的连接。
