【提问】 问关于QT/E安装的问题
我使用的工具如下
fedora 3 kernel 2.6.9-1.667
tmake-2.12
qt/e 3.3.4
qt-x11-3.3.5
gcc-3.4
elf-3.2.1
qt-x11-3.3.5编译完成UIC也已经CP
然后
export TMAKEDIR=/home/client/tmake-2.12
export TMAKEPATH=$TMAKEDIR/lib/qws/linux-arm-g++
export PATH=$TMAKEDIR/bin:$PATH
export TMAKEPATH PATH
export QT2DIR=/home/client/qt-x11-free-3.3.5
export QTDIR=QT2DIR
export QTDIR=/home/client/qt-3.3.4
export PATH=$QTDIR/bin:$PATH
export LD_LIBRARY_PATH=$QTDIR/lib:$LD_LIBRARY_PATH
export QTDIR PATH LD_LIBRARY_PATH
gcc-3.4 elf-3.2.1路径也已经设好
cp了 /usr/include下的fenv.h到qt目录下的include
进入QT/E目录
./configure -embedded arm -shared -no-cups -no-ipv6 -no-gfx-qvfb -qconfig
make
arm-linux-g++ -W1, -rpath /lib -o t1.obj/release-shared-emb-arm/main.o
-L/home/qt3.3.5/lib -lqte -ldl
/home/client/qt-3.3.5/lib/libqte.s undefined reference to `fesetenv'
/home/client/qt-3.3.5/lib/libqte.s undefined reference to `feholdexcept'
collect2: ld returned 1 exit status
make[3]: *** [../../bin/assistant] 错误 1
make[3]: Leaving directory `/home/client/qt-3.3.5/tools/assistant'
make[2]: *** [sub-assistant] 错误 2
make[2]: Leaving directory `/home/client/qt-3.3.5/tools'
make[1]: *** [sub-tools] 错误 2
make[1]: Leaving directory `/home/client/qt-3.3.5'
make: *** [init] 错误 2
请帮忙解释下这个问题是什么意思,如何解决 谢谢
| 电子价签墨水屏开发被打赏¥35元 | |
