D12,ZLG 学生有D12的问题请教ZLG的老师们
在D12_ReadEndpoint()中有这么一段:
每次读完D12_DATA以后,D12_DATA端口的数据是自动更新的么?连续读取数据,D12怎么知道MCU已经读过了的?问题可能有点傻请老师不要笑话,谢谢!
D12_COMMAND = 0xF0;
j = D12_DATA;
j = D12_DATA;
if(j > len)
j = len;
for(i=0; i<j; i++)
*(buf+i) = D12_DATA;
unsigned char D12_ReadEndpoint(unsigned char endp, unsigned char len, unsigned char * buf)
unsigned char i, j;
if(bEPPflags.bits.in_isr == 0)
DISABLE;
D12_COMMAND = endp;
i=D12_DATA;
if((i & D12_FULLEMPTY) == 0) {
ENABLE;
return 0;
D12_COMMAND = 0xF0;
j = D12_DATA;
j = D12_DATA;
if(j > len)
j = len;
for(i=0; i<j; i++)
D12_COMMAND = 0xF2;
ENABLE;
return j;
答 1: re:D12是通过读写引脚信号线识别数据被读取或写入,当然D12的CS引脚也有使能的作用. 答 2: 哦,谢谢您!
D12_COMMAND = 0xF0;
j = D12_DATA;
j = D12_DATA;
if(j > len)
j = len;
for(i=0; i<j; i++)
unsigned char i, j;
DISABLE;
D12_COMMAND = endp;
i=D12_DATA;
ENABLE;
return 0;
D12_COMMAND = 0xF0;
j = D12_DATA;
j = D12_DATA;
if(j > len)
j = len;
for(i=0; i<j; i++)
D12_COMMAND = 0xF2;
ENABLE;
return j;
| 电子价签墨水屏开发被打赏¥35元 | |
