167 请教一个167的A/D问题,很急~~~
为什么我用这段14X的程序把include改成16X的,得到的AD数值总是0呢?
这段程序是在TI下的,不会有问题吧?
谢谢大家了
// MSP-FET430P140 Demo - ADC12, Using the Internal Reference
// This example shows how to use the internal reference of the ADC12.
// It uses the internal 2.5V reference and performs a single conversion
// on channel A0. The conversion results are stored in ADC12MEM0. Test by
// applying a voltage to channel A0, then setting and running to a break point
// at the "_NOP()" instruction. To view the conversion results, open an ADC12 register
// window in C-Spy and view the contents of ADC12MEM0.
// MSP430F149
// | A0 (P6.0)|<---- Vin
// M.Mitchell
// Texas Instruments, Inc
// February,2002
// Built with IAR Embedded Workbench Version: 1.25A
// December 2003
// Updated for IAR Embedded Workbench Version: 2.21B
#include "MSP430x16x.h" // Standard Equations
void main(void)
unsigned int i;
WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer
P6SEL |= 0x01; // Enable A/D channel A0
ADC12CTL0 = ADC12ON+SHT0_2+REFON+REF2_5V; // Turn on and set up ADC12
ADC12CTL1 = SHP; // Use sampling timer
ADC12MCTL0 = SREF_1; // Vr+=Vref+
for ( i=0; i<0x3600; i++) // Delay for reference start-up
ADC12CTL0 |= ENC; // Enable conversions
while (1)
ADC12CTL0 |= ADC12SC; // Start conversion
while ((ADC12IFG & BIT0)==0);
_NOP(); // SET BREAKPOINT HERE
} 答 1: 可以的呀
这段程序是在TI下的,不会有问题吧?
谢谢大家了
// MSP430F149
// M.Mitchell
// February,2002
// December 2003
void main(void)
unsigned int i;
while (1)
} 答 1: 可以的呀
| 电子价签墨水屏开发被打赏¥35元 | |
