电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » M-T-8-8-8-8-初-始-化-的-问-题
2006-09-17 18:14:16     打赏
关键词: M-T-8-8-8-8-
2006-12-22 22:43:00     打赏
问 A software reset must be included at the beginning of all programs to initialize the control registers after power up.The initialization procedure should be implemented 100ms after power up.
初始化程序应该在上电后100mS内完成,还是100mS外?
还有就是21IC被禁止使用的词语也太多了,多到我根本看不出来!黑暗! 答 1: 真搞不懂,我这个题目有什么古怪!居然非要分开了才算不含违禁词语?????????
