// Copyright (c) 1992,1993,1994, Exemplar Logic Inc. All rights reserved.
// Description :
// This Verilog HDL description implements a UART.
// Version 1.1 : Original Creation
// 2.1 : added comments
// Download from: http://www.fpga.com.cn
module uart (clkx16, read, write, rx, reset, tx, rxrdy, txrdy,
parityerr, framingerr, overrun, data);
input clkx16; // Input clock. 16x bit clock
input read; // Received data read strobe
input write; // Transmit data write strobe
input rx; // Receive data line
input reset; // clear dependencies
output tx; // Transmit data line
output rxrdy; // Received data ready to be read
output txrdy; // Transmitter ready for next byte
output parityerr; // Receiver parity error
output framingerr; // Receiver framing error
output overrun; // Receiver overrun error
inout [0:7] data; // Bidirectional data bus
reg tx; // Transmit data line
reg overrun; // Receiver overrun error
reg framingerr; // Receiver framing error
reg parityerr; // Receiver parity error
// Transmit data holding register
wire [0:7] txhold ;
// Transmit shift register bits
reg [0:7] txreg;
reg txtag2 ; // tag bits for detecting
reg txtag1 ; // empty shift reg
reg txparity ; // Parity generation register
// Transmit clock and control signals
reg txclk ; // Transmit clock: 1/16th of clkx16
wire txdone ; // 1'b1 when shifting of byte is done
wire paritycycle ; // 1'b1 on next to last shift cycle
reg txdatardy ; // 1'b1 when data is ready in txhold
// Receive shift register bits
reg [0:7] rxhold; // Holds received data for read
reg [0:7] rxreg; // Receive data shift register
reg rxparity ; // Parity bit of received data
reg paritygen ; // Generated parity of received data
reg rxstop ; // Stop bit of received data
// Receive clock and control signals
reg rxclk ; // Receive data shift clock
reg rxidle ; // 1'b1 when receiver is idling
reg rxdatardy ; // 1'b1 when data is ready to be read
reg [2:0] cnt;
// Toggle txclk every 8 counts, which divides the clock by 16
always @(posedge clkx16)
begin
if (reset)
txclk = 1'b0;
else if (cnt == 3'b000)
txclk = !txclk;
if (reset)
cnt = 3'b000;
else
cnt = cnt + 1;
end
reg [0:3] rxcnt; // Count of clock cycles
reg rx1, hunt; //rx delayed one cycle, Hunting for start bit
begin
// rxclk = clkx16 divided by 16
rxclk = rxcnt[0];
// Hunt=1 when we are looking for a start bit:
// A start bit is eight clock times with rx=0 after a falling edge
if (reset)
hunt = 1'b0;
else if (rxidle && !rx && rx1 )
// Start hunting when idle and falling edge is found
hunt = 1'b1;
else if (!rxidle || rx )
// Stop hunting when shifting in data or a 1 is found on rx
hunt = 1'b0;
rx1 = rx; // rx delayed by one clock for edge detection
// (Must be assigned AFTER reference)
// Increment count when not idling or when hunting
if (!rxidle || hunt)
// Count clocks when not rxidle or hunting for start bit
rxcnt = rxcnt + 1;
else
// hold at 1 when rxidle and waiting for falling edge
rxcnt = 4'b0001;
end
always @(posedge txclk)
begin
if (txdone && txdatardy)
begin
// Initialize registers and load next byte of data
txreg = txhold; // Load tx register from txhold
txtag2 = 1'b1; // Tag bits for detecting
txtag1 = 1'b1; // when shifting is done
txparity = 1'b1; // Parity bit. Initializing to 1 = odd parity
tx = 1'b0; // Start bit
end
else
begin
// Shift data
// bug in assigning to slices
// txreg(0 TO 6) = txreg(1 TO 7);
// txreg(7) = txtag1;
txreg = {txreg[1 : 7], txtag1};
txtag1 = txtag2;
txtag2 = 1'b0;
// Form parity as each bit goes by
txparity = txparity ^ txreg[0];
// Shift out data or parity bit or stop/idle bit
if (txdone )
tx = 1'b1; // stop/idle bit
else if (paritycycle)
tx = txparity; // Parity bit
else
tx = txreg[0]; //Shift data bit
end
end
// paritycycle = 1 on next to last cycle (When txtag2 has reached txreg(1))
// (Enables putting the parity bit out on tx)
assign paritycycle = txreg[1] && !(txtag2 || txtag1 ||
txreg[7] || txreg[6] || txreg[5] ||
txreg[4] || txreg[3] || txreg[2]);
// txdone = 1 when done shifting [When txtag2 has reached tx]
assign txdone = !(txtag2 || txtag1 ||
txreg[7] || txreg[6] || txreg[5] || txreg[4] ||
txreg[3] || txreg[2] || txreg[1] || txreg[0]);
// Shift data on each rxclk when not idling
always @(posedge rxclk)
begin
if (rxidle)
// Load all ones when idling
begin
rxreg = 8'b11111111;
rxparity = 1'b1;
paritygen = 1'b1; // Odd parity
rxstop = 1'b0;
end
else
// Shift data when not idling
// rxreg (0 TO 6) = rxreg (1 TO 7);
// rxreg(7) = rxparity;
begin
rxreg = {rxreg [1 : 7], rxparity};
rxparity = rxstop;
paritygen = paritygen ^ rxstop; // Form parity as data shifts by
rxstop = rx;
end
end
// rxidle requires async preset since it is clocked by rxclk and
// its value determines whether rxclk gets generated
always @(posedge rxclk or posedge reset)
begin
if (reset)
rxidle = 1'b0;
else
rxidle = !rxidle && !rxreg[0];
end
// Load txhold and set txdatardy on falling edge of write
// Clear txdatardy on falling edge of txdone
reg wr1,wr2; // write signal delayed 1 and 2 cycles
reg txdone1; // txdone signal delayed one cycle
begin
if (reset)
txdatardy = 1'b0;
else if (!wr1 && wr2)
// Falling edge on write signal. New data in txhold latches
txdatardy = 1'b1;
else if (!txdone && txdone1)
// Falling edge on txdone signal. Txhold has been read.
txdatardy = 1'b0;
// Delayed versions of write and txdone signals for edge detection
wr2 = wr1;
wr1 = write;
txdone1 = txdone;
end
reg rd1, rd2 ; // Read input delayed 1 and 2 cycles
reg rxidle1 ; // rxidle signal delayed 1 cycle
begin
// Look for rising edge on idle and update output registers
if (rxidle && !rxidle1)
begin
if (rxdatardy)
// Overrun error if previous data is still there
overrun = 1'b1;
else
begin
// No overrun error since holding register is empty
overrun = 1'b0;
// Update holding register
rxhold = rxreg;
// paritygen = 1 if parity error
parityerr = paritygen;
// Framingerror if stop bit is not 1
framingerr = !rxstop;
// Signal that data is ready for reading
rxdatardy = 1'b1;
end
end
rxidle1 = rxidle; // rxidle delayed 1 cycle for edge detect
// Clear error and data registers when data is read
if (!rd2 && rd1)
begin
rxdatardy = 1'b0;
parityerr = 1'b0;
framingerr = 1'b0;
overrun = 1'b0;
end
rd2 = rd1; // Edge detect for read
rd1 = read; // (Must be assigned AFTER reference)
if (reset)
rxdatardy = 1'b0;
end
// Drive data bus only during read
assign data = read ? rxhold : 8'bzzzzzzzz;
// Latch data bus during write
assign txhold = write ? data : txhold;
// Receive data ready output signal
assign rxrdy = rxdatardy;
// Transmitter ready for write when no data is in txhold
assign txrdy = !txdatardy;
endmodule
Verilog HDL 程序举例--数据接口:
关键词: Verilog 程序 举例 数据 接口 write
| 为遥控小车巧添功能被打赏¥26元 | |
