共1条
keyboard programming(老站转)
水木清华
助理工程师
来自:
发表总数:4
查看 短消息 电子邮件 引用 回复
发信人: haowai (号外), 信区: DriverDev
标 题: keyboard programming
发信站: BBS 水木清华站 (Mon Apr 1 20:17:17 2002)
觉得很好,转贴一下
by Wout Mertens
The computer and the AT or MF II interface through I/O ports 60h and
64h, controlled by a programmable Intel 8042 (old ATs), 8741 or 8742
(newer, allow two input devices (like the PS/2 mouse)) microprocessor
or compatible, which allows typematic rate programming, LEDs lighting
and some other stuff. It also has a +-20 byte output buffer for smooth
operation and long scancodes.
The old XT keyboard has a 8048, which is in essence just a very
primitive one-way serial interface, so all used is port 61h, to disable
and reenable the keyboard on every scancode.
Port 60h: Input & output
Read: Scancodes and keyboarddata
This port gives the following output codes:
00h: Keyboard error, too many keys are being pressed at once
aah: Basic Assurance Test (BAT) end
abh 41h: The result of requesting keyboard ID on a MF II keyboard
eeh: The result of the echo command
fah: ACK(noledge). Sent by every command, except eeh and feh
fch: BAT failed
feh: Resend your data please
ffh: Keyboard error
All the rest are make (press) and break (release) codes of the keys.
Write: Command data
This is the place where command data has to be sent. If the command
consists of two bytes, you must wait until the outputbuffer is sent to
the keyboard. Check on it via bit 1 of port 64h. When you send a
command, the outputbuffer is cleared, so pending results may not come.
During transmission of a two-byte command, the keyboard stops scanning.
When you send something out of range or so, the keyboard will react
with feh (resend). All commands, except echo (eeh) and resend (feh)
result in ACK (fah) to be sent.
Commands:
edh: Set keyboard LEDs
Send a second byte with:
bit 0 = Scroll Lock 0=Off 1=On
1 = Num Lock
2 = Caps Lock
rest = 0
Do make an effort to keep the BIOS keyboard flags in sync.
eeh: Great fun. Send it, and get 0eeh right back! :-]
(Diagnostics)
f0h: Select scancode set.
0: return current set number: 1:'C', 2:'A', 3:'?'
1: set scancode set no 1
2: set scancode set no 2 -> standard
3: set scancode set no 3
f2h: Identify keyboard
XT: nothing (that is, time-out error :-) (see port 64h)
AT: ACK
MF II: ACK abh 41h
f3h: Typematic rate programming
bit 0 -> 4: rate. Timings:
0: 30 keys/sec 10: 10
1: 26.7 13: 9
2: 24 16: 7.5
4: 20 20: 5
8: 15 31: 2
bit 5 & 6: pause before repeat:
0: 250 ms
1: 500
2: 750
4: 1000
bit 7: Always 0
The next three are doubtfull, since one of my sources say they don't
exist and another says they do. I leave it up to you :)
f4h: Enable keyboard. It clears its buffer and starts scanning.
f5h: Reset keyboard, disable scanning
f6h: Reset keyboard, enable scanning
feh: Resend last transmission. I really don't know what it does, since
it sends something incomprehesible.
ffh: Internal diagnostics: Sends aah if successfull. Warning! The
keyboard reacts with ACK and then you have to set the data and
clock pins high, DURING AT LEAST 500 SECONDS!. Do this via the
outputport (see 64h). After that, the BAT (Basic Assurance Test)
starts. This sends aah on success and fch on failure.
Example: Set the keyboard LEDs
start:
in al, 64h \It would be good
and al, 02h ;Test if command buffer is empty |to put this in a
jnz start /macro...
mov al, edh
out 60h, al ;Write outputport
wait:
in al, 64h
and al, 02h ;Test if command came through
jnz wait
mov al, 0111b
out 60h, al ;Set all LED's to ON.
Port 61h
This port is used to acknoledge the receival of a scancode, by
disabling the keyboard and immediately reenabling it. This also means
that you can read a scancode as many times as you like, until you
acknoledge the receival.
bit 0 -> 5: Nothing to do with keyboard, but with the Programmable
Peripheral Interface (PPI) -> save them!
bit 6: Hold keyboard clock low -> Keyboard can't send any data.
bit 7: 0=Enable keyboard; 1=Disable keyboard
Example:
in al, 61h
mov ah, al ;Save keyboard status
or al, 80h ;Disable
out 61h, al
mov al, ah ;Enable (If it was disabled at first, you wouldn't
out 61h, al ; be doing this anyway :-)
Port 64h: Interface: data and control
Read: Statusport
bit 0: 1: Keyboard data is in buffer
0: Output buffer empty -> use it to check for results
1: 1: User data is in buffer
0: Command buffer is empty -> time to send a command
2: 1: Selftest successful
0: Reset (?)
3: 1: 64h was last accessed port
0: 60h was last accessed port
4: 1: Keyboard enabled
0: Keyboard locked
5: PS/2: Mouse interface
6: 1: Time-out error occurred: Keyboard or PS/2 mouse didn't
react. Use the Resend command to retry fetching the data
byte. This could happen when trying to get a XT keyboard
to do something :).
7: 1: Last transmission had a parity error
Write: Control register
This is the control room of the keyboard interface. If additional data
is required, send it to port 60h after writing the command to 64h.
Also, check 61h bit 2 before sending anything.
Commands:
aah: Keyboard self test. Sends 55h if successfull.
abh: Test interface. Sends:
00h: No error
01h: Clock low
02h: Clock high
03h: Data low
04h: Data high
ffh: Total Error
adh: Deactivate keyboard
aeh: Activate keyboard
c0h: Read inputport. This is some highly specialized stuff and I wonder
why I am typing this. Ok. The inputport is that what the keyboard
is sending and some more. Layout:
bit 0: Keyboard data in pin
1: PS/2 mouse in pin
2->5: reserved
6: Wether you have a color or mono screen
7: 1: Keyboard not locked
0: Keyboard locked
When you issue this command, the inputport is put on the
outputbuffer, so you have the great priviledge of reading it at
port 60h.
c1h: Puts the low nibble of the input port over bits 4-7 of the
statusport, so you can read them out continuously. This lasts
until bit 2 of the statusport gets set, meaning you are sending
data to the keyboard.
c2h: Ditto, but it puts the high nibble over bits 0-3 of the
statusport. Lifespan is the same.
d0h: Puts the outputport on the buffer. Layout:
bit 0: 1: Reset processor
1: 1: A20 gate enable
2: PS/2 mouse data out
3: PS/2 mouse clock signal
4: 1: Output buffer full
5: 1: Output buffer PS/2 mouse full
6: Keyboard clock signal
7: Keyboard data out
Bit 0 and 1 are quite important for high memory and
286-extended-memory access.
d1h: Write the following data byte to the outputport
d2h: Write the following data byte to the keyboardbuffer. This is VERY
handy for TSRs that need to read codes that start with e0h. This
way, they don't have to pass through the e0h, unless they know for
sure it isn't their code, which results in correct functioning
shift keys etc. At least, if it does what I think it
does... [UNTESTED]
d3h: Ditto, for PS/2 mouse.
d4h: Write byte to PS/2 mouse.
e0h: Reads the keyboards testinputs, T0 and T1. T0 goes to bit 0 and T1
to bit 1 of the byte that is put on the outputbuffer.
fxh: I think it sends x to the low nibble of the output port. It does
reset my computer when I send feh, but that doesn't mean anything
:-). The official explanation says that it keeps the corresponding
bits in the output port low for 6ms...
Example: Send something to the outputport
start:
and al, 02h ;Test if command buffer is empty|to put this in a
jnz start /macro...
mov al, d1h
out 64h, al ;Write outputport
wait:
jnz wait
mov al, 01h
out 60h, al
关键词: keyboard programming 老站转
共1条
| 「AI编程记录--含源码」用一晚上的时间写一个esp32的示波器被打赏¥19元 | |
| STM32C0116DK开发探索记(3)被打赏¥30元 | |
| STM32C0116DK开发探索记(2)被打赏¥24元 | |
| STM32C0116DK开发探索记(1)被打赏¥29元 | |
