电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » AT91SAM9261 SDRAM 133 MHz Core 266 MHz
2009-03-24 16:48:17     打赏
//   ATMEL Microcontroller Software Support  -  ROUSSET  -
// The software is delivered "AS IS" without warranty or
// condition of any  kind, either express, implied or
// statutory. This includes without limitation any warranty
// or condition with respect to merchantability or fitness
// for any particular purpose, or against the infringements of
// intellectual property rights of others.
//  File: SAM9_SDRAM.mac
//  User setup file for CSPY debugger.
//  1.1 08/Aug/06 jpp    : Creation
//  $Revision: 26510 $
__var __mac_i;
__var __mac_pt;
*       execUserReset() : JTAG set initially to Full Speed
execUserReset()
    __message "------------------------------ execUserReset ---------------------------------";
    _MapRAMAt0();                       //* Set the RAM memory at 0x00300000 & 0x00000000
    __PllSetting();                     //* Init PLL
    __PllSetting100MHz();
    __message "-------------------------------Set PC Reset ----------------------------------";
*       execUserPreload() : JTAG set initially to 32kHz
execUserPreload()
    __message "------------------------------ execUserPreload ---------------------------------";
    __hwReset(0);                     //* Hardware Reset: CPU is automatically halted after the reset (JTAG is already configured to 32kHz)
    __writeMemory32(0xD3,0x98,"Register"); //*  Set CPSR
    __initSDRAM();                    //* Init SDRAM before load
    _MapRAMAt0();                     //* Set the RAM memory at 0x0020 0000 & 0x0000 0000
    _InitRSTC();                      //* Enable User Reset to allow execUserReset() execution
*       _InitRSTC()
* Function description
*   Initializes the RSTC (Reset controller).
*   This makes sense since the default is to not allow user resets, which makes it impossible to
*   apply a second RESET via J-Link
_InitRSTC() {
    __writeMemory32(0xA5000001, 0xFFFFFD08,"Memory");    // Allow user reset
*       __initSDRAM()
* Set SDRAM for works at 100 MHz
__initSDRAM()
//* Configure EBI Chip select
//    pCCFG->CCFG_EBICSA |= AT91C_EBI_CS1A_SDRAMC;
// AT91C_CCFG_EBICSA ((AT91_REG *)  0xFFFFEF1C) // (CCFG)  EBI Chip Select Assignement Register
    __writeMemory32(0x0001003A,0xFFFFEE30,"Memory");
//*  Configure PIOs
//* AT91F_PIO_CfgPeriph( AT91C_BASE_PIOC, AT91C_PC16_D16 to AT91C_PC16_D31
// pPio->PIO_ASR = periphAEnable; AT91C_PIOC_ASR ((AT91_REG *) 0xFFFFF870) // (PIOC) Select A Register
// pPio->PIO_BSR = periphBEnable;AT91C_PIOC_BSR  ((AT91_REG *) 0xFFFFF874) // (PIOC) Select B Register
// pPio->PIO_PDR = (periphAEnable | periphBEnable); // Set in Periph mode
    __writeMemory32(0xFFFF0000,0xFFFFF870,"Memory");
    __writeMemory32(0x00000000,0xFFFFF874,"Memory");
    __writeMemory32(0xFFFF0000,0xFFFFF804,"Memory");
//* psdrc->SDRAMC_CR =  AT91C_SDRAMC_NC_9  | AT91C_SDRAMC_NR_13 | AT91C_SDRAMC_CAS_2 |
//  AT91C_SDRAMC_NB_4_BANKS | AT91C_SDRAMC_DBW_32_BITS | AT91C_SDRAMC_TWR_2 | AT91C_SDRAMC_TRC_7 |
//  AT91C_SDRAMC_TRP_2 | AT91C_SDRAMC_TRCD_2 | AT91C_SDRAMC_TRAS_5 | AT91C_SDRAMC_TXSR_8 ;
//    __writeMemory32(0x85227259,0xFFFFEA08,"Memory");
    __writeMemory32(0xA6339279,0xFFFFEA08,"Memory");
 __sleep(100);
//* psdrc->SDRAMC_MR = 0x00000002;  // Set PRCHG AL
    __writeMemory32(0x00000002,0xFFFFEA00,"Memory");
//* *AT91C_SDRAM = 0x00000000;   // Perform. PRCHG
    __writeMemory32(0x00000000,0x20000000,"Memory");
 __sleep(100);
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 1st CBR
      __writeMemory32(0x00000004,0xFFFFEA00,"Memory");
//* *(AT91C_SDRAM+4) = 0x00000001; // Perform. CBR
    __writeMemory32(0x00000001,0x20000010,"Memory");
//* psdrc->SDRAMC_MR = 0x00000004;  // Set 2 CBR
//* *(AT91C_SDRAM+8) = 0x00000002; // Perform. CBR
     __writeMemory32(0x00000002,0x20000020,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 3 CBR
//* *(AT91C_SDRAM+0xc) = 0x00000003; // Perform. CBR
     __writeMemory32(0x00000003,0x20000030,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 4 CBR
//* *(AT91C_SDRAM+0x10) = 0x00000004; // Perform. CBR
     __writeMemory32(0x00000004,0x20000040,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 5 CBR
//* *(AT91C_SDRAM+0x14) = 0x00000005; // Perform. CBR
     __writeMemory32(0x00000005,0x20000050,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 6 CBR
//* *(AT91C_SDRAM+0x18) = 0x00000006; // Perform. CBR
     __writeMemory32(0x00000006,0x20000060,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 7 CBR
//* *(AT91C_SDRAM+0x1c) = 0x00000007; // Perform. CBR
     __writeMemory32(0x00000007,0x20000070,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_RFSH_CMD;  // Set 8 CBR
//* *(AT91C_SDRAM+0x20) = 0x00000008; // Perform. CBR
     __writeMemory32(0x00000008,0x20000080,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_LMR_CMD;  // Set LMR operation
      __writeMemory32(0x00000003,0xFFFFEA00,"Memory");
//* *(AT91C_SDRAM+0x24) = 0xcafedede;  // Perform. LMR burst="1", lat="2"
     __writeMemory32(0xCAFEDEDE,0x20000090,"Memory");
//* psdrc->SDRAMC_TR = (AT91C_MASTER_CLOCK * 7)/1000000;    // Set Refresh Timer 390 for 25MHz (TR= 15.6 * F )
//                        // (F : system clock freq. MHz
      __writeMemory32(0x000002b7,0xFFFFEA04,"Memory");
//* psdrc->SDRAMC_MR = AT91C_SDRAMC_MODE_NORMAL_CMD;  // Set Normal mode
      __writeMemory32(0x00000000,0xFFFFEA00,"Memory");
//* *AT91C_SDRAM = 0x00000000; // Perform. Normal mode
   __message "------------------------------- SDRAM Done at 133 MHz -------------------------------";
*       _MapRAMAt0()
* Remap RAM at 0
_MapRAMAt0()
  __var hold;
  // Test and set Remap
  hold = __readMemory32(0x00000000,"Memory");
  __writeMemory32(0xAAAAAAAA,0x00000000,"Memory");
  if(__readMemory32(0x00000000,"Memory") != 0xAAAAAAAA)
    __writeMemory32(0x03,0xFFFFEE00,"Memory");    // toggle remap bits
  else
    __writeMemory32(hold,0x00000000,"Memory");
*       __PllSetting()
*   Initializes the PMC.
*   1. Enable the Main Oscillator
*   2. Configure PLL
*   3. Switch Master
__PllSetting()
     if ((__readMemory32(0xFFFFFC30,"Memory")&0x3) != 0 ) {
//* Disable all PMC interrupt ( $$ JPP)
//* AT91C_PMC_IDR   ((AT91_REG *) 0xFFFFFC64) //(PMC) Interrupt Disable Register
//*    pPmc->PMC_IDR = 0xFFFFFFFF;
    __writeMemory32(0xFFFFFFFF,0xFFFFFC64,"Memory");
//* AT91C_PMC_PCDR  ((AT91_REG *) 0xFFFFFC14) //(PMC) Peripheral Clock Disable Register
    __writeMemory32(0xFFFFFFFF,0xFFFFFC14,"Memory");
// Disable all clock only Processor clock is enabled.
    __writeMemory32(0xFFFFFFFE,0xFFFFFC04,"Memory");
// AT91C_PMC_MCKR  ((AT91_REG *)  0xFFFFFC30) // (PMC) Master Clock Register
    __writeMemory32(0x00000001,0xFFFFFC30,"Memory");
    __sleep(10000);
// write reset value to PLLA and PLLB
// AT91C_PMC_PLLAR ((AT91_REG *)  0xFFFFFC28) // (PMC) PLL A Register
    __writeMemory32(0x00003F00,0xFFFFFC28,"Memory");
// AT91C_PMC_PLLBR ((AT91_REG *)  0xFFFFFC2C) // (PMC) PLL B Register
    __writeMemory32(0x00003F00,0xFFFFFC2C,"Memory");
    __sleep(10000);
   __message "------------------------------- PLL  Enable -----------------------------------------";
   } else {
   __message " ********* Core in SLOW CLOCK mode ********* "; }
*       __PllSetting100MHz()
*   Set core at 266 MHz and MCK at 133 MHz
*  133120000 * 2 = 266240000
   __message "------------------------------- PLL Set at 133 MHz ----------------------------------";
//* pPmc->PMC_MOR = (( AT91C_CKGR_OSCOUNT & (0x40 <<8) | AT91C_CKGR_MOSCEN ));
    __writeMemory32(0x00004001,0xFFFFFC20,"Memory");
    __sleep(10000);
    __sleep(10000);
//*   AT91C_BASE_CKGR->CKGR_PLLAR = (AT91C_CKGR_SRCA | ((96 << 16) & AT91C_CKGR_MULA) |
//    (AT91C_CKGR_PLLACOUNT | (AT91C_CKGR_OUTA_0 | (9);
//    __writeMemory32(0x2060BF09,0xFFFFFC28,"Memory");
    __writeMemory32(0x2081BF09,0xFFFFFC28,"Memory");
    __sleep(10000);
// AT91C_BASE_PMC->PMC_PLLBR = BOARD_USBDIV| BOARD_CKGR_PLLB | BOARD_PLLBCOUNT | BOARD_MULB| BOARD_DIVB;
    __writeMemory32(0x20813F0C,0xFFFFFC2C,"Memory");
   __sleep(10000);
//*   AT91C_BASE_PMC->PMC_MCKR =  AT91C_PMC_CSS_PLLA_CLK | AT91C_PMC_PRES_CLK | AT91C_PMC_MDIV_2;;
    __writeMemory32(0x00000102,0xFFFFFC30,"Memory");
     __sleep(10000);
/// Frequency of the board main oscillator.
#define BOARD_MAINOSC           18432000
/// Master clock frequency (when using board_lowlevel.c).
#define BOARD_MCK               133120000   //((18432000 * 97 / 9) / 2)
#define BOARD_OSCOUNT           (AT91C_CKGR_OSCOUNT & (64 << 8))
#define BOARD_CKGR_PLLA         (AT91C_CKGR_SRCA | AT91C_CKGR_OUTA_2)
#define BOARD_PLLACOUNT         (63 << 8)
//#define BOARD_MULA              (AT91C_CKGR_MULA & (96 << 16))
//#define BOARD_DIVA              (AT91C_CKGR_DIVA & 9)
#define BOARD_MULA              (AT91C_CKGR_MULA & (129 << 16))
#define BOARD_PRESCALER         AT91C_PMC_MDIV_2
#define BOARD_USBDIV            AT91C_CKGR_USBDIV_2
#define BOARD_CKGR_PLLB         AT91C_CKGR_OUTB_0
#define BOARD_PLLBCOUNT         BOARD_PLLACOUNT
#define BOARD_MULB              (124 << 16)
#define BOARD_DIVB              12
    // CFG Control Register
    WRITE(AT91C_BASE_SDRAMC, SDRAMC_CR, AT91C_SDRAMC_NC_9
                                        | AT91C_SDRAMC_NB_4_BANKS
                                        | sdrc_dbw
                                        | AT91C_SDRAMC_TRP_2
                                        | AT91C_SDRAMC_TXSR_8);
关键词: AT91SAM9261     SDRAM     0x00000
2009-04-09 20:51:53     打赏
超低价部分原装IGBT销售
7MBR10SA120 此型号现货是拆机9.8成新
BSM15GP60
BSM75GB120DLC
FP10R12KE3ENG
FP15R12KE3ENG
FP25R12KT3
FP40R12KT3
FS75R12KT3G
FS150R12KT3
FF150R12KE3G
FF300R12KT3
P185A1001
FP25R12KT3
FP40R12KT3
FP50R12KT3
FP75R12KT3
P089C
FF300R12KE3
FF300R12KT3
FF200R12KE3
FF400R12KE3
TEL:0755-8250 8350
QQ:253743134 私聊
MSN:limazhou@hotmail.com
