电子产品世界 » 论坛首页 » 综合技术 » 工业控制与自动化 » 西门子plc可以替代fb41的程序
西门子plc可以替代fb41的程序
2009-03-25 12:50:55     打赏
西门子plc可以替代fb41的程序
 CLR
      A     #init
      JC    ini0
      L     "sysdb".ms
      T     #msold
      L     0
      T     #sv_sel
//     L     #PV
//   T     #sv1
      SET
      S     #sample
      S     #init
      L     #sv1
      T     #svn_1
ini0: NOP   0
      CLR
      L     "sysdb".ms
      L     #msold
      -D
      JM    s000
      JU    s001
s000: L     DW#16#7FFFFFFF
      +D
s001: L     #CYCLE
      <D
      JC    s002
      L     "sysdb".ms
      T     #msold
      S     #sample                     //generate sample pulse
s002: NOP   0
      L     #CYCLE
      DTR
      L     1.000000e+003
      /R
      T     #TA                         //ta=cycle in s real
      L     #TA
      L     2.000000e+000
      /R
      T     #tTA2
      L     #TI
      DTR
      L     1.000000e+003
      /R
      T     #TN                         //tn=ti in s real
      L     #tTA2
      <R
      JCN   A7d0
      T     #TN                         //judge ti
A7d0: L     #TD
      DTR
      L     1.000000e+003
      /R
      T     #TV                         //tv=td in s real
      L     #TM_LAG
      DTR
      L     1.000000e+003
      /R
      T     #TVD                        //tvd=tm_lag in s real
      L     #tTA2
      <R
      JCN   A7d1
      T     #TVD                        //judge tm_lag
A7d1: CLR
      A     #INV_SENSE                  //judge n&p default is negative
      JCN   A7d2
      L     #GAIN
      L     -1.000000e+000
      *R
      T     #KP                         //kp=-1*gain when positive
      JU    A7d3
A7d2: L     #GAIN
      T     #KP                         //kp=gain when negative
A7d3: NOP   0
      CLR
      L     #sv_sel                     //do sv select  man
      L     0
      ==I
      JCN   sv00
      SET
      S     #man_on
      R     #cas_on
sv00: NOP   0
      CLR
      L     #sv_sel                     //do sv select  auto
      L     1
      ==I
      JCN   sv01
      SET
      R     #man_on
      R     #cas_on
sv01: NOP   0
      CLR
      L     #sv_sel                     //do sv select   cas
      L     2
      ==I
      JCN   sv02
      SET
      R     #man_on
      S     #cas_on
sv02: NOP   0
      CLR
      A     #cas_on
      JCN   cas0
      L     #sv2
      T     #svn
      T     #sv1
cas0: CLR
      A     #cur_on
      JCN   cur0
      L     #sv3
      T     #svn
      T     #sv1
cur0: CLR
      A     #mod_on
      JCN   mod0
      L     #sv5
      T     #svn
      T     #sv1
      JU    mod1
mod0: NOP   0
      L     #sv1
      T     #svn
mod1: NOP   0
      CLR
      A     #sv_vel_on
      JCN   vel1
      CLR
      A     #sample
      JCN   vel0
      CLR
      L     #svn
      L     #svn_1
      -R
      ABS
      L     #sv_vel_lim
      >=R
      JCN   vel1                        //judge dsv
      CLR
      L     #svn
      L     #svn_1
      >R
      JCN   vel3
      L     #svn_1
      L     #sv_vel_lim
      +R
      L     #svn
      TAK
      >R
      JCN   vel1
      L     #svn_1
      L     #sv_vel_lim
      +R
      T     #sv
      JU    vel0
vel3: CLR
      L     #svn
      L     #sv_vel_lim
      +R
      L     #svn_1
      TAK
      >R
      JCN   vel1
      L     #svn_1
      L     #sv_vel_lim
      -R
      T     #sv
      JU    vel0
vel1: NOP   0
      L     #svn
      T     #sv
vel0: NOP   0
      L     #sv
      T     #sp                         //end sv process
      L     #sp
      L     #PV
      -R
      T     #ER                         //calculate er="sp-pv"
      NEGR                              //start er alarm check
      T     #er_neg
      L     #erhh
      >R
      JCN   a000
      S     #erhh_alm
a000: TAK
      L     #erh
      >R
      JCN   a001
      S     #erh_alm
a001: TAK
      L     #erl
      <R
      JCN   a002
      S     #erl_alm
a002: TAK
      L     #erll
      <R
      JCN   a003
      S     #erll_alm
a003: NOP   0
      L     #erhh
      L     #alm_hys
      -R
      L     #er_neg
      >=R
      JCN   a004
      R     #erhh_alm
a004: L     #erh
      L     #alm_hys
      -R
      L     #er_neg
      >=R
      JCN   a005
      R     #erh_alm
a005: L     #erl
      L     #alm_hys
      +R
      L     #er_neg
      <=R
      JCN   a006
      R     #erl_alm
a006: L     #erll
      L     #alm_hys
      +R
      L     #er_neg
      <=R
      JCN   a007
      R     #erll_alm                   //process er alarm check
a007: CLR
      A     #man_on                     //process pv check
      JC    pv01
      CLR
      L     #PV
      L     #pvn_1
      -R
      ABS
      L     5.000000e+001
      >R
      JCN   pv00
      S     #pv_error                   //set when dpv>50.0
pv00: NOP   0
      CLR
      A     #pv_error
      JCN   pv01
      S     #man_on
      R     #pv_error
pv01: NOP   0
      CLR
      A     #DEADB_ON                   //deadband on_off default is off
      JCN   A7d4
      CLR
      L     #ER
      L     #DEADB_DN
      <R
      JCN   A7d5
      L     #ER
      L     #DEADB_DN
      -R
      T     #tER
      JU    A7d9
A7d5: CLR
      L     #ER
      L     #DEADB_UP
      >R
      JCN   A7d7
      L     #ER
      L     #DEADB_UP
      -R
      T     #tER
      JU    A7d9
A7d7: L     0.000000e+000
      T     #tER
      JU    A7d9
A7d4: L     #ER
      T     #tER                        //store er in ter
A7d9: L     #tER
      L     #KP
      *R
      T     #ERxKP                      //calc erxkp="er"*kp
      L     #PV
      L     #KP
      *R
      T     #PVxKP                      //calc pvxkp="pv"*kp
      CLR
      A     #COM_RST                    //restart when true
      JCN   A7da
      L     "sysdb".ms                  //start reset procee
      T     #msold
      L     0.000000e+000
      T     #LMN_D                      //lmn_d=0
      A     #I_SEL
      JCN   A7db
      A     #PFDB_SEL
      JCN   A7dc
      L     #PVxKP
      NEGR
      T     #LMN_I                      //lmn_i=-1*pvxkp
      JU    A7dd
A7dc: L     #ERxKP
      NEGR
      T     #LMN_I                      //lmn_i=-1*erxkp
A7dd: CLR
      A     #DISV_SEL
      JCN   A7df
      L     #LMN_I
      L     #DISV
      -R
      T     #LMN_I                      //lmn_i=lmn_i-disv
      JU    A7df
A7db: L     0.000000e+000
      T     #LMN_I                      //lmn_i=0 when i_sel=0
A7df: L     0.000000e+000
      T     #PID_OUTV                   //reset output to 0 end restart
      L     #svn
      T     #svn_1
      R     #COM_RST
A7da: NOP   0                           //end reset
      CLR
      A     #man_on
      JCN   A7e0                        //do when man_on=1 start manual process
      L     0.000000e+000
      T     #LMN_D                      //lmn_d=0
      A     #PID_OUTV_RST
      NOT
      JCN   A7e0
      A     #I_SEL
      JCN   A7e2
      A     #PFDB_SEL
      JCN   A7e3
      L     #LMN
      L     #PVxKP
      -R
      T     #LMN_I
      JU    A7e4
A7e3: L     #LMN
      L     #ERxKP
      -R
      T     #LMN_I
A7e4: CLR
      A     #DISV_SEL
      JCN   A7e6
      L     #LMN_I
      L     #DISV
      -R
      T     #LMN_I
      JU    A7e6
A7e2: L     0.000000e+000
      T     #LMN_I
A7e6: L     #LMN
      T     #PID_OUTV                   //end manual mode process
A7e0: NOP   0
      CLR
      A     #mv_trksv                   //track down
      JCN   trk0
      L     #dsv
      T     #LMN
trk0: NOP   0
      CLR
      A     #trk_mv_on                  //track fmv
      JCN   fmv0
      L     #trk_mv
      T     #LMN
fmv0: NOP   0
      CLR
      A     #mv_trksv
      O     #trk_mv_on
      JCN   B7e0                        //do mv track process
      L     0.000000e+000
      T     #LMN_D                      //lmn_d=0
      A     #PID_OUTV_RST
      NOT
      JCN   B7e0
      A     #I_SEL
      JCN   B7e2
      A     #PFDB_SEL
      JCN   B7e3
      L     #LMN
      L     #PVxKP
      -R
      T     #LMN_I
      JU    B7e4
B7e3: L     #LMN
      L     #ERxKP
      -R
      T     #LMN_I
B7e4: CLR
      A     #DISV_SEL
      JCN   B7e6
      L     #LMN_I
      L     #DISV
      -R
      T     #LMN_I
      JU    B7e6
B7e2: L     0.000000e+000
      T     #LMN_I
B7e6: L     #LMN
      T     #PID_OUTV                   //end mv track process
B7e0: NOP   0
      CLR
      A     #PID_OUTV_RST
      JCN   A7e7
      L     0.000000e+000               //do when pid_outv_rst=1
      T     #LMN_D
      L     #LMN_I
      L     #PID_OUTVold
      -R
      L     #RST_VAL_OUTV
      +R
      T     #LMN_I
      L     #RST_VAL_OUTV
      T     #PID_OUTV                   //end rest output
A7e7: CLR
      A     #sample
      JCN   A7e8
      CLR                               //do when sample is true
      A     #man_on
      O     #mv_trksv
      O     #trk_mv_on
      NOT
      JCN   sa00
      A     #P_SEL                      //do when man_on=0 start auto prcess
      JCN   A7e9
      A     #PFDB_SEL
      JCN   A7ea
      L     #PVxKP
      T     #LMN_P
      JU    A7ec
A7ea: L     #ERxKP
      T     #LMN_P
      JU    A7ec
A7e9: L     0.000000e+000
      T     #LMN_P                      //calc lmn_p
A7ec: CLR
      A     #ITL_ON
      JCN   A7ed
      L     #I_ITLVAL
      T     #LMN_I
      JU    A7ee
A7ed: CLR
      A     #I_SEL
      JCN   A7ef
      A     #INT_HOLD
      NOT
      JCN   A7ee
      L     #ERxKP
      L     #TN
      /R
      L     #TA
      *R
      L     #LMN_I
      +R
      T     #LMN_I
      L     #LMN_P
      +R
      L     #LMN_HLM
      >R
      JCN   A7f1
      L     #LMN_HLM
      L     #LMN_P
      -R
      T     #LMN_I
A7f1: L     #LMN_P
      L     #LMN_I
      +R
      L     #LMN_LLM
      <R
      JCN   A7f2
      L     #LMN_LLM
      L     #LMN_P
      -R
      T     #LMN_I
A7f2: JU    A7ee
A7ef: L     0.000000e+000
      T     #LMN_I                      //calc lmn_i
A7ee: CLR
      A     #D_SEL
      JCN   A7f4
      A     #DFDB_SEL
      JCN   A7f5
      L     #PVxKP
      L     #PVold
      -R
      T     #YD
      JU    A7f6
A7f5: L     #ERxKP
      L     #ERold
      -R
      T     #YD
A7f6: L     #YD
      L     #TV
      *R
      L     #TA
      /R
      T     #YD
      L     0.000000e+000
      >R
      JCN   A7f7
      TAK
      L     #LMN_D
      >R
      JCN   A7f7
      TAK
      T     #LMN_D
A7f7: L     #YD
      L     0.000000e+000
      <R
      JCN   A7f9
      TAK
      L     #LMN_D
      <R
      JCN   A7f9
      TAK
      T     #LMN_D
A7f9: L     2.000000e+000
      L     #TVD
      *R
      L     #TA
      -R
      L     2.000000e+000
      TAK
      T     #t_tvd
      TAK
      L     #TVD
      *R
      L     #TA
      +R
      L     #t_tvd
      TAK
      /R
      L     #LMN_D
      *R
      T     #LMN_D
      JU    A7fb
A7f4: L     0.000000e+000
      T     #LMN_D                      //calc lmn_d
A7fb: L     #LMN_P
      L     #LMN_I
      +R
      L     #LMN_D
      +R
      T     #PID_OUTV
      CLR
      A     #DISV_SEL
      JCN   A7fc
      L     #DISV
      +R
      T     #PID_OUTV
A7fc: L     #PID_OUTV
      L     #LMN_HLM
      >R
      JCN   A7fd
      T     #PID_OUTV
A7fd: L     #PID_OUTV
      L     #LMN_LLM
      <R
      JCN   A7fe
      T     #PID_OUTV                   //calc pid_outv
A7fe: L     #PVxKP
      T     #PVold
      L     #ERxKP
      T     #ERold
      L     #PID_OUTV
      T     #PID_OUTVold
      T     #LMN
sa00: L     #PV
      T     #pvn_1
      L     #sp
      T     #svn_1
      R     #sample                     //end auto mode process
A7e8: NOP   0
      CLR
      L     #LMN
      L     1.000000e+002
      >=R
      JCN   lmn0
      L     1.000000e+002
      JU    lmn9
lmn0: TAK
      CLR
      L     0.000000e+000
      <=R
      JCN   lmn1
      L     0.000000e+000
      JU    lmn9
lmn1: TAK
lmn9: T     #LMN
      L     #LMN
      L     2.764800e+002
      *R
      RND
      T     #mv_per
      BE
关键词: 西门子     可以     替代     程序     0.000000e+00
