电子产品世界 » 论坛首页 » 论坛服务 » 论坛公告 » Rhapsody v4.1 MR2 (C) I-Logix
共9条 1/1 1 跳转至页
2003-08-30 19:02:37     打赏
苘 圹圹 圮 ?谀 捋圹?圹圹 哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? 圹圹苘苘圹圹圹圹苘圹? - TEAM ROR presents - ? 捋圹圹圹圹圹圹圹圹哌 ? 捋哌 ? 圹郯郯 Rhapsody v4.1 MR2 (C) I-Logix ? ?圹圹捋舶 哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? 圹圹 捋?苒? SUPPLIER: TEAM ROR PROGRAM TYPE: DEVELOPMENT? 圹圹?圹佰圹? CRACKER : TEAM ROR PROTECTION : FLEXLM ? 圹圹?圹圹圹? PACKAGER: TEAM ROR RELEASE TYPE: LICENSE ? 苒圹郯 圹圹郯 哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? 苒圹圹? 圹圹? ROR PLATFORM: WIN32 RELEASE DATE: 08-20-2003 ? 苒圹圹郯 苒圹圹圹 苘郾?LANGUAGE: ENGLISH ARCHIVE NAME: RORILR41.R*? 圹圹圹郯 佰圹圹圹圹圹?FORMATS: BIN/CUE RELEASE SIZE: 18 x 15MB ? 佰圹卑 滥哪? 圹圹圹圹郾澳哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪馁 圹圹圹脖? 圹鄄卑 谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? ?氨槽 RELEASE INFORMATION ? 滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? Traditional system and software development is commonly divided in two main areas: front-end analysis and design, and back-end implementation and test, strung together serially. CASE tools were originally created to automate the planning and analysis phase. While some of these tools provided some design capture ability, and minimal code frame generation, none linked the design to the implementation and the documentation. This disconnect continues today in that as soon as the requirements specifications are handed down, the system architecture begins to deviate from the specifications. Most often this is because the requirements are ambiguous, consequently, these propagations are handed down into further phases of development. If that isn't enough, as soon as coding begins, the implementation more often than not diverges from the design documentation, introducing another disconnect, increasing project risk, lowering overall system quality and maintainability, and lengthening the development lifecycle. Equally, since CASE tools were oblivious to behavior, they did nothing to solve the trauma of system integration. Since behavior is unknown until system integration, this phase is normally a hot spot in the development life cycle. It only gets worse when the pressure to increase functionality, improve quality and keep to schedule with fewer resources drives development teams to take risky short-cuts in attempts to recover time. Whether the team is disciplined or in free fall, one thing is certain, waiting until the end of the development cycle to first address behavior adds incredible risk to the process. It is odd that chip designs are validated continually during the development process while software validation is postponed until the very end. It is no wonder that hardware design productivity improves at a high rate while software productivity is stuck at essentially the same level year after year. Rhapsody reverses the traditional design process, allowing you to find problems as they occur, versus waiting until the very end when they are far more costly to correct. Rhapsody provides a collaborative Model-Driven Development (MDD) environment for system and software engineers enabling you to work in an iterative fashion where you can quickly analyze and make rapid system and software design changes, generate an application and test the ramifications of your changes quickly and efficiently, up front. Decisions are validated as they are made through constant and consistent testing while designing. You do not wait for systems integration to validate your design decisions. Instead, you iterate and validate continually, all the while building new functionality on top of proven behavior so that when you are done, you are really done, saving development time, energy and expense. For more information: http://www.ilogix.com 谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? ?氨槽 INSTALL NOTES ? 滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? Unpack and Burn, look into /crack folder for install info. Enjoy this fine release from TEAM ROR :) 谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? ?氨槽 TEAM ROR AGREEMENTS ? 滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? Attention: Please read these terms carefully before using our release. Using our release indicates that you have read and accepted these agreements. If you do not agree to accept these terms, do not use our release or infomation from it. We may change the terms of this Agreement at any time. YOU MAY USE OUR RELEASE FOR EVALUATION PRUPOSES ONLY. WE WILL NOT BE HELD RESPONSIBLE FOR OUR RELEASE. IF YOU LIKE THIS SOFTWARE, YOU'RE STRONGLY ADVISED TO BUY IT. SOFTWARE COMPANIES NEED SUPPORT FOR QUALITY PRODUCTS. YOU MAY NOT USE OUR RELEASE TO MAKE MONEY OR USE IT FOR COMMERCIAL PURPOSE. 谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? ?氨槽 TEAM ROR NEWS ? 滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? We have changed our email address, Please find at bottom of the page. Wanna Join? Getting In Touch With Us If... - You are familiar with commercial protections (Flexlm,Dongle,etc...) - You can do keygen for generic software - You can supply unreleased quality softwares 谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? ?氨槽 TEAM ROR GREETS ? 滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? TEAM ROR send GREETS to: All groups who bring releases of high quality to the scene. 谀哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? ?氨槽 CONTACT INFORMATION ? 滥哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? Contact Us: RORteam[at]hotbox[dot]ru
关键词: Rhapsody     I-Logix     圹圹     哪哪
2003-09-02 17:56:00     打赏
xiaohua , 4.1的在那里呀? 想用一下.
2003-09-02 18:18:00     打赏
Ok,我有空上载一下!
2003-10-09 18:32:00     打赏
I am sorry! I will upload next day! But where?
2003-10-09 19:22:00     打赏
我也等了很久了, 那个4.0简直搞死我了. 放到认证的gao, 可能过些时间会被删掉.
2003-10-09 19:43:00     打赏
收到!明天开工!
2003-10-10 23:22:00     打赏
7楼
4.1的已经上载了,4.2的还没看到!不知道谁能把它~~~~~~~~
2003-10-11 00:14:00     打赏
8楼
谢谢 xiaohua, 已经下载了, 晚上回去研究研究, 白天没时间.
2003-10-11 00:16:00     打赏
9楼
不客气,助人为快乐之本嘛!:)
共9条 1/1 1 跳转至页
