电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » GNU相关补丁和源代码
GNU相关补丁和源代码
2003-11-07 18:20:04     打赏
https://secure.windriver.com/cgi-bin/windsurf/downloads/dispProdList.cgi?productid=102 PATCHES Identifier Required Name Headline Product Version cum-patch.src.tor3_1.all.020116 Optional t31GnuSrcCDUpdate1.tar.gz Update to the T3.0 GNU Source CD for T3.1. GNU Tools 2.x src.ppc405-patch.ppc.020116 Optional ppc405-patch.tar.gz Patch set for PowerPC 405 support in the GNU toolchain. GNU Tools 2.x T21SH-spr73519 Mandatory GNU Compiler patch for Hitachi SuperH GNU Compiler patch for Tornado 2.1 for Hitachi SuperH GNU Tools 2.x VxGDB 5.3 for Tornado 2.2 CP1 with Diab 5.1.1 Mandatory VxGDB 5.3 patch for Tornado 2.2 CP1/ PowerPC VxGDB 5.3 patch for Tornado 2.2 CP1/PowerPC for Diab 5.1.1 comdat GNU Tools 2.x 84407-coldfire Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / ColdFire VxGDB 5.3 upgrade for Tornado 2.2 / ColdFire (TDK-14627) GNU Tools 2.x 84407-m68k Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / 68K VxGDB 5.3 upgrade for Tornado 2.2 / 68K (TDK-14626) GNU Tools 2.x 84407-mips Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / MIPS VxGDB 5.3 upgrade for Tornado 2.2 / MIPS (TDK-14623) GNU Tools 2.x 84407-pentium Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / Pentium VxGDB 5.3 upgrade for Tornado 2.2 / Pentium (TDK-14621) GNU Tools 2.x 84407-ppc Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / PowerPC VxGDB 5.3 upgrade for Tornado 2.2 / PowerPC (TDK-14620) GNU Tools 2.x 84407-sh Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / SuperH VxGDB 5.3 upgrade for Tornado 2.2 / SuperH (TDK-14625) GNU Tools 2.x 84407-src Optional VxGDB 5.3 upgrade for Tornado 2.2 / source VxGDB 5.3 upgrade for Tornado 2.2 / source GNU Tools 2.x 84407-arm Mandatory VxGDB 5.3 upgrade for Tornado 2.2 / ARM/SA/XScale VxGDB 5.3 upgrade for Tornado 2.2 / ARM/SA/XScale (TDK-14622,TDK-14624) GNU Tools 2.x 84407-418-src Optional VxGDB 4.18 CP1 sources VxGDB 4.18 CP1 source distribution GNU Tools 2.x 80790 Optional 80790 Patch adds handling for Toshiba Tx49xx instructions to MIPS toolchain. Use the new '-mcpu=4900' option to enable the use of the new instructions. GNU Tools 2.x 73419 Mandatory Cumulative Patch for GNU C++ Compiler (Tornado 2.0 and 2.0.2 for PowerPC) This patch fixes a number of SPRs present in the GNU 2.7.2 C++ compiler for Tornado 2.0 and 2.0.2 PowerPC. GNU Tools 2.x 71523 Mandatory Cumulative Patch for GNU Compiler (Tornado 2.1 for PowerPC MPC74xx/MPC750) This patch fixes a number of SPRs present in the GNU 2.96 compiler for Tornado 2.1 PowerPC MPC74xx/MPC750 GNU Tools 2.x 70942 Mandatory Patched XScale GCC compiler to complete structure packing when using pragma pack 1. The bug, XScale GCC compiler version 2.9-010413 that pragma pack 1 does not cause complete structure packing, is fixed by this patch. GNU Tools 2.x 70559 Optional Tcl fix for SPR 70559 in Tornado 2.2 SPR 70559: variables with nested base classes cannot be viewed in watch window GNU Tools 2.x 68185 Optional Compiler patch for the Tornado 2.1 for Hitachi SuperH Release(gcc 2.96) gcc: optimization causes loop to execute once (-O2) rather than five times (-O0) (-O0) (-O0) (-O0) (-O0) (-O0) (-O0) (-O0) (-O0) (-O0) GNU Tools 2.x 29880 Mandatory Patch for GNU compiler (-frepo) option g++: -frepo does not instantiate all of the necessary templates. GNU Tools 2.x 29516 Mandatory PowerPC T2.0 x86-win32 C++ Compiler: general protection fault, internal compiler error, & unknown software exception g++: 'controlnode' test case generates "unknown software exception" on Windows, works on Solaris Solaris Solaris Solaris GNU Tools 2.x 28268 Optional Patch cc960 structure packing gcc: Cannot get the compiler to pack the items in a structure on i960, nor does #pragma work in C++ C++ GNU Tools 2.x 27977 Mandatory C++ and RAD-6000: 'make' fails multiple definition of __vec_new & __vec_delete GNU Tools 2.x 27816 Optional Problem with Nested Classes g++: problem with nested classes GNU Tools 2.x 24682 Optional cc960 on WinNT4.0 Produces Dr. Watson Application Error gcc: cc960 produces Dr Watson application error under Windows NT 4.0 GNU Tools 2.x -no identifier defined- Optional arm-wrs-vxworks-src.tor2 1 1.arm-cumulative.patch.021119.tgz Cumulative patch sources for Tornado 2.1.1 GNU ARM compiler GNU Tools 2.x BSPS No BSPs found. DRIVERS No Drivers found. SAMPLE CODE No Sample Code found. MISCELLANEOUS DOWNLOADS Identifier Headline Product Version arm-wrs-vxworks-src.tor2_1_1.arm-cumulative.patch.021119.tgz Cumulative patch sources for Tornado 2.1.1 GNU ARM compiler GNU Tools 2.x cum-patch.tor2_0.all.20030902 Tornado 2.0 cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_0.arm.20030716 Tornado 2.0 arm cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_0.ppc.20030219+29880 Special Tornado 2.0 powerpc cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_1.arm.20030606 Tornado 2.1 arm cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_1_0.superh.20030325 Tornado 2.1.0 superh cumulative patch for gnu compilers GNU Tools 2.x cum-patch.tor2_2.all.030107 Tornado 2.2 cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.arm.030716 Tornado 2.2 arm cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.arm.031028 Tornado 2.2 arm cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.mips.030716 Tornado 2.2 mips cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.mips.031022 Tornado 2.2 mips cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.pentium.030731 Tornado 2.2 pentium cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.pentium.031010 Tornado 2.2 pentium cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.powerpc.030724 Tornado 2.2 powerpc cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.powerpc.031031 Tornado 2.2 powerpc cumulative patch for gnu tools GNU Tools 2.x cum-patch.tor2_2.sh.030724 Tornado 2.2 sh cumulative patch for gnu tools GNU Tools 2.x GDB 4.18, cum. patch 1 GDB 4.18, cumulative patch 1, for Tornado 2.2. (Superseded by 84407 PATCHES above) GNU Tools 2.x gdb5.3comdat_arm_thumb VxGDB 5.3 patch for Tornado 2.2 CP1 / ARM/THUMB with Diab 5.1.1 GNU Tools 2.x gdb5.3comdat_ColdFire VxGDB 5.3 patch for Tornado 2.2 CP1 / ColdFire with Diab 5.1.1 GNU Tools 2.x gdb5.3comdat_mips VxGDB 5.3 patch for Tornado 2.2 CP1 / MIPS with Diab 5.1.1 GNU Tools 2.x gdb5.3comdat_ppc VxGDB 5.3 patch for Tornado 2.2 CP1 / PowerPC with Diab 5.1.1 GNU Tools 2.x gdb5.3comdat_SuperSH VxGDB 5.3 patch for Tornado 2.2 CP1 / SuperSH with Diab 5.1.1 GNU Tools 2.x GNU ARM Tools Source 030528 Tornado 2.2 source code for GNU ARM tools GNU Tools 2.x GNU MIPS Tools Source 030528 Tornado 2.2 source code for GNU MIPS tools GNU Tools 2.x GNU Pentium Tools Source 030527 Tornado 2.2 source code for GNU Pentium tools GNU Tools 2.x GNU PowerPC Tools Source 030521 Tornado 2.2 source code for GNU PowerPC tools GNU Tools 2.x GNU SH / 68k Tools 030522 Tornado 2.2 Source code for GNU SH and 68K GNU Tools 2.x mips-wrs-vxworks-src.tor2_1_1.mips-fcs.021028.tgz Tornado 2.1.1 source code for GNU MIPS tools GNU Tools 2.x patch-tor2_1_0.mips.030819.tgz Tornado 2.1.0 mips cumulative patch for gnu tools GNU Tools 2.x src.tor2_1.pc7400-cumulative.patch.ppc.020416 Tornado 2.1 cumulative patch source code for GNU PPC 74xx tools GNU Tools 2.x src.tor2_1.ppc7400-f1.ppc.020416 Tornado 2.1 source code for GNU PPC 74xx tools. GNU Tools 2.x src.tor2_2-f.gdb.021120 Tornado 2.2 Source code for GNU debugger (all architectures) GNU Tools 2.x t221gdbsrc.tgz VxGDB 5.3 sources for Tornado 2.2.1 and Tornado 2.2 CP1 GNU Tools 2.x tor2_2.powerpc.030724 Tornado 2.2 powerpc cumulative patch for gnu tools GNU Tools 2.x VxGDB 5.3 patch for Tornado 2.2 CP1 / PowerPC with Diab 5.1.1 VxGDB 5.3 patch for Tornado 2.2 CP1 / PowerPC with Diab 5.1.1 GNU Tools 2.x 85859-simNT Fix to GNU simNT toolchain for SPR 85859 GNU Tools 2.x
关键词: 相关     补丁     源代码     Optional     Tools
