电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » Easykit 试用笔记
Easykit 试用笔记
2010-12-20 17:35:49     打赏
开发工具已经用了,用在磁条卡数据的读取上,虽然内存很小,但我也可以正确地读到了磁条卡的数据。。现发一下源代码,连线就不用了,看源文件里的定义就知道了。如果不明白的,可以直接EMAIL给我。
完全保证源文件可用!
附件怎么传的,我怎么没看到传附件的地方?
把代码贴在这里算了
 .h 文件
//#include "mb95200.h"
#include "gpio.h"
//  Define I/O port for SPCB006E
#define ioCLD    PDR0_P06  // data signal valid
#define ioTrack2Dat PDR0_P01  // data input
#define ioTrack2Clk PDR0_P02  // clock input
// Define macro
#define  HI                1
#define  LO               0
#define  TRUE              1
#define  FALSE             0
union byte_bit_s {
  unsigned char bb;
  struct {
   unsigned b7;
   unsigned b6;
   unsigned b5;
   unsigned b4;
   unsigned b3;
   unsigned b2;
   unsigned b1;
   unsigned b0;
  } bs;
typedef union byte_bit_s byte_bit_t;
// Track Buffer Size
#define READ_TRACK2BUFSIZE   60
// Track Start Code & End Code
#define READ_TRACK1_STARTCODE  0x45
#define READ_TRACK1_ENDCODE   0x7C
#define READ_TRACK23_STARTCODE 0x0B
#define READ_TRACK23_ENDCODE  0x1F
// Error Code
#define READ_LRCERROR      0xF1
#define READ_PARITYERROR    0xF2
#define READ_NOENDCODE     0xF3
#define READ_NOSTARTCODE    0xF4
#define READ_NODATA       0xF5
// Track Data Buffer
void ReadyToRead(void);
void Track2Check(void);
void Track2Decode(void);
extern unsigned char chTrack2Buffer[READ_TRACK2BUFSIZE];
extern unsigned char chTrack2Buf1;     //Track3 Data Buffer1 for recieve data
extern unsigned char chTrack2Buf2;     //Track3 Data Buffer2 for recieve data
extern unsigned char chTrack2Index;     //Track3 Data Buffer index for recieve data
extern unsigned char chTrack2Counter;    //Track3 Data bit counter for recieve data
extern unsigned char nReadTrack2Len;
#define fTrack2Start   flag2.bs.b0    //Track3 Start recieve data , it be set by Track3 Receive
#define fTrack2Direction flag2.bs.b1    //Track3 Swipe direction: 1:Forward / 0:Reserve , it be set by Track3Interrupt
#define fTrack2HaveData  flag2.bs.b2
#define fTrack2StartEnd  flag2.bs.b3
#define ftemp       flag2.bs.b4
#define fParity1     flag2.bs.b5
#define fParity2     flag2.bs.b6
 .c 文件
#include "mcard.h"
unsigned char chTemp;
byte_bit_t flag2;
// Track Data Buffer Define
void ReadyToRead(void) {
 chTrack2Buf1    = 0;
 chTrack2Buf2    = 0;
 chTrack2Index   = 0;
 chTrack2Counter  = 0;
 fTrack2Start    = 0;
 fTrack2StartEnd  = 0;
 fTrack2HaveData  = 0;
 fTrack2Direction  = 0;
 nReadTrack2Len   = 0;
 flag2.bb      = 0;
// Track Data Decode
void Track2Decode(void) {
 unsigned char i;
 __DI();
 if( (!gpio_get(ioTrack2Clk)) && (!gpio_get(ioCLD)) )  {
  fTrack2HaveData = TRUE;
    ftemp = !gpio_get(ioTrack2Dat);
    if( fTrack2Start )  {
   if( fTrack2Direction ) {
    chTrack2Buf1 = chTrack2Buf1 >> 1;
    if( ftemp ) {
          chTrack2Buf1 = chTrack2Buf1 | 0x10;
   else {
    if( ftemp ) {
     chTrack2Buf1 = chTrack2Buf1 | 0x01;
    chTrack2Buf1 = chTrack2Buf1 << 1;
   chTrack2Counter++;
   if( chTrack2Counter == 5 ) {
    if( chTrack2Index < READ_TRACK2BUFSIZE - 1 )  {
     chTrack2Buffer[chTrack2Index++] = chTrack2Buf1;
     chTrack2Buf1 = 0x00;
    else {
  // waiting for start code or end code
  else  {
   chTemp = chTrack2Buf1 & 0x01 ;
   if( ftemp ) {
   chTrack2Buf2 = chTrack2Buf2 >> 1;
   if( chTemp ) {
    chTrack2Buf2 = chTrack2Buf2 | 0x10;
   // check Track2 end code
   if( ( chTrack2Buf1 & 0x1F ) == READ_TRACK23_ENDCODE ) {
    // [ Start Code ] + [ End Code ] or [ End Code ] + [ Start Code ]
    if( ( chTrack2Buf2 & 0x1F ) == READ_TRACK23_STARTCODE ) {
     chTrack2Buffer[chTrack2Index++] = chTrack2Buf2;
     fTrack2Start = TRUE;
     fTrack2Direction = TRUE;
     fTrack2StartEnd = TRUE;
    // [ LRC ] + [ End Code ]
    else {
     // Check Parity
     //ACC = chTrack2Buf2;
     for(i = 0;i < 5; i++) {
      if(chTrack2Buf2 & (1<<i)) fParity2 = !fParity2;
     if( fParity2 ) {
      chTrack2Buffer[chTrack2Index++] = 0x1F;
      fTrack2Direction = FALSE;
      fTrack2StartEnd = FALSE;
   // check Track2 start code
   // [ Start Code ] + [ Data ] + [ End Code ] + [ LRC ]
   else {
     // Check Parity
     //ACC = chTrack2Buf1;
      if(chTrack2Buf1 & (1<<i)) fParity1 = !fParity1;
     if( fParity1 ) {
  while(!gpio_get(ioTrack2Clk)) {}  // wait end low level
 __EI();
// Track Data Check
void Track2Check(void) {
 int i = 0,j = 0,k = 0,nTemp = 0,m = 0;
 for(i = chTrack2Index; i > 1; i--) {
  if( chTrack2Buffer[i] != 0x00 )
   break;
 if( i < 2 ) {
  nReadTrack2Len = READ_NODATA;
  return;
 nReadTrack2Len = i+1;
 // [ Start Code ] + [ End Code ] + [ LRC ]
 // or [ LRC ] = [ Start Code ]
 if( fTrack2StartEnd && ( nReadTrack2Len > 3 ) ) {
  // LRC
  for(i = 0; i < 5; i++)  {
   nTemp = nTemp << 1;
   if( ( chTrack2Buffer[0] >> i ) & 0x01 )
    nTemp++;
  chTrack2Buffer[0] = nTemp;
  for(i = 2; i < nReadTrack2Len; i++)  {
   nTemp = 0;
   for(j = 0;j < 5; j++)   {
    nTemp = nTemp << 1;
    if( ( chTrack2Buffer[i] >> j ) & 0x01 )
     nTemp++;
   chTrack2Buffer[i] = nTemp;
  j = nReadTrack2Len >> 1;
  k = nReadTrack2Len - 1;
  for(i = 0;i < j; i++)  {
   nTemp = chTrack2Buffer[i];
   chTrack2Buffer[i] = chTrack2Buffer[k];
   chTrack2Buffer[k] = nTemp;
   k--;
 // Reverse
 // [ LRC ] + [ End Code ] + [ Data ] + [ Start Code ]
 if( !fTrack2Direction ) {
  // LRC Process
   nTemp = nTemp << 1;
    nTemp++;
  // Data Process
   chTrack2Buffer[i] = chTrack2Buffer[i] >> 1;
  j = nReadTrack2Len>>1;
  k = nReadTrack2Len-1;
  for(i = 0; i < j; i++)  {
   k--;
  for(j = 0; j < 2; j++)  {
   // Check Start Code ( Error Code = 0xF4 )
   if( chTrack2Buffer[0] != READ_TRACK23_STARTCODE )   {
    for(i=nReadTrack2Len-1;i>0;i--)    {
     nTemp = ( chTrack2Buffer[i-1] >> 3 ) & 0x03;
     chTrack2Buffer[i] = ( ( chTrack2Buffer[i] << 2 ) + nTemp ) & 0x1F;
    chTrack2Buffer[0] = ( chTrack2Buffer[0] << 2 ) & 0x1F;
    if( chTrack2Buffer[0] == 0x00 )    {
     for(i=0;i<nReadTrack2Len;i++)
      chTrack2Buffer[i] = chTrack2Buffer[i+1];
     nReadTrack2Len--;
  nReadTrack2Len = READ_NOSTARTCODE;
  return;
 // Check End Code ( Error Code = 0xF3 )
 if( chTrack2Buffer[nReadTrack2Len-2] != READ_TRACK23_ENDCODE ) {
  nReadTrack2Len = READ_NOENDCODE;
  return;
 // Check Parity ( Error Code = 0xF2 )
 for(i = 0;i < nReadTrack2Len; i++) {
  //nTemp = chTrack2Buffer[i];
  //ACC = nTemp;
  for(m = 0;m < 5; m++) {
   if(chTrack2Buffer[i] & (1<<m)) fParity1 = !fParity1;
  if( !fParity1 ) {
   nReadTrack2Len = READ_PARITYERROR;
   return;
 // Check LRC ( Error Code = 0xF1 )
 nTemp = chTrack2Buffer[0];
 for(i = 1; i < nReadTrack2Len - 1; i++) {
  nTemp = nTemp ^ chTrack2Buffer[i];
 nTemp = nTemp & 0x0F;
 if( nTemp != ( chTrack2Buffer[nReadTrack2Len-1] & 0x0F ) )  {
  nReadTrack2Len = READ_LRCERROR;
  return;
 // Data Process
 for(i = 0; i < nReadTrack2Len - 1; i++) {
  chTrack2Buffer[i] = ( chTrack2Buffer[i] & 0x0F ) + 0x30;
 nReadTrack2Len--;
// Usage
void Init (void) {
 DDR0_P06   = 0;  //
 ioCLD    = 0;  //
 DDR0_P01   = 0;  //
 ioTrack2Dat = 0;  //
 DDR0_P02   = 0;  //
 ioTrack2Clk = 0;  //
void main (void) {
 Init ();              // Config Hardware
 ReadyToRead();           // Clear Buffers
 while(1) {
  // .....mcard start.....
  if( !ioCLD )  {         // "!ioCLD" replaceed with "!gpio_get(ioCLD)" If Signal Input
   while( !ioCLD ) {        // "!ioCLD" replaceed with "!gpio_get(ioCLD)"
    Track2Decode();
    // clrwdt();
   }                // Wait Signal End
   if( fTrack2HaveData ) {
    Track2Check();
    // clrwdt();
    // out_msg();         // print card message here
   else {
   ReadyToRead();         // Clear Buffers For Next Time
  // ....mcare end......
关键词: Easykit     试用     笔记     #define     uns
2010-12-20 20:01:47     打赏
不错,继续~~~~~~~~
