An increasing number of applications require DC/DC converters that produce an output that falls somewhere within the input voltage range. The problem is that conventional buck-boost converter topologies, such as SEPIC or boost followed by buck, are complex, inefficient and consume a relatively large board area. Linear Technology offers 4-switch-topology buck-boost regulators that significantly improve efficiency and save space, but a complete regulator design still requires a number of external components and meticulous board layout decisions related to electrical and thermal considerations. The next clear step to simplify the design is a modular approach—a buck-boost regulator system in an IC form factor. The LTM4605 and LTM4607 μModule™ buck-boost regulators take that approach. Each requires only one external inductor and a single sensing resistor to produce a compact, high performance, high efficiency buck-boost regulator with exceptional thermal performance.
μModule Buck-Boost Regulators Offer a Simple and Efficient.pdf
打赏帖 | |
【Freertos】任务管理被打赏10分 | |
分享博世的两种不同的喷射系统模式被打赏5分 | |
汽车+开路实验与短路实验被打赏10分 | |
多点式电子控制汽油喷射系统知识分享被打赏10分 | |
分享机械控制式汽油喷射系统被打赏5分 | |
汽车显示屏——第2部分:TFTLCD、OLED和micro-LED显示屏电源技术被打赏50分 | |
汽车+汽车电路板的走线规则被打赏20分 | |
五一劳动节快乐被打赏5分 | |
【分享开发笔记,赚取电动螺丝刀】s32k146适配zephyr(六)使用Ozone调试镜像被打赏29分 | |
【分享开发笔记,赚取电动螺丝刀】s32k146适配zephyr(五)添加设备树节点被打赏33分 |
