电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » A Simple Thermistor Interface to an ADC
2012-04-12 17:48:13     打赏
关键词: half bridge, thermistor, ADC, A/D converter, NTC, PTC, ratiometric, negative temperature coefficent, position temperature coefficent, analog to digital converters
Abstract: This article describes a simple and cost effective method of measuring temperature using a thermistor connected in a half-bridge configuration. The goal is to perform a ratiometric measurement such that the VREF source voltage to the divider is the same as the reference to the analog-to-digital converter (ADC) used to measure the voltage at VT.
 A Simple Thermistor Interface to an ADC.pdf
关键词: Simple     Thermistor     Interfa
