电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Analysis of ADC System Distortion Caused
Analysis of ADC System Distortion Caused by Source Resistance
2012-04-12 18:06:11     打赏
关键词: ADC, analog to digital converter, voltage divider, distortion, gain error, high impedance, low impedance, sampling capacitor, time constant, a/d converters
Abstract: Analog-to-digital converter (ADC) data sheets and application typically recommend driving their inputs with a low source impedance. This application note explains the possible effects such as increased gain error and distortion when using high impedance to drive an ADC without a buffer.
  Analysis of ADC System Distortion Caused by Source Resistance.pdf
关键词: Analysis     System     Distortio
