电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Precision DAC and Watchdog Improve Analo
Precision DAC and Watchdog Improve Analog Output Safety
2012-04-13 17:35:12     打赏
关键词: uP supervisor, microprocessor supervisor, analog io, DAC, optocoupler, digital analog converter, programmable logic controller, PLC, data acquisition
Abstract: Using a DAC and a microprocessor supervisor, the system safety can be improved in industrial controllers, programmable-logic controllers (PLC), and data-acquisition systems. The analog output is set to zero-scale (or pin-programmable midscale) when a microprocessor failure, optocoupler failure, or undervoltage condition occurs. A simple application is shown on how to implement this function.
 Precision DAC and Watchdog Improve Analog Output Safety.pdf
关键词: Precision     Watchdog     Improv
