电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Visible-Laser Driver Has Digitally Contr
Visible-Laser Driver Has Digitally Controlled Power Modulation
2012-04-13 17:53:12     打赏
关键词: modulated laser, diode driver, visible-light laser, optical, photodiode, photo diode, peak optical power, visible laser driver
Abstract: The circuit in the figure below includes a 10-bit digital-to-analog converter (DAC) with 3-wire serial input that operates and maintains a visible-light laser diode at constant average optical output power. A separate digital input line (MOD) enables a comparator with open-drain output (IC4) to implement digital communications by pulsing the laser-diode through Q1.
 Visible-Laser Driver Has Digitally Controlled Power Modulation.pdf
关键词: Visible-Laser     Driver     Digi
