电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » ARINC 429 总线
ARINC 429 总线
2012-04-13 20:32:32     打赏
ARINC 429 Bus
The ARINC 429 Decode and Symbolic solution is the ideal tool for system level protocol debug as well as problem solving for signal quality issues. The ARINC 429 Decode and Symbolic package adds a unique set of tools to your oscilloscope, simplifying how you design and debug ARINC 429 systems.
Key Features
  • Add symbolic labels to ARINC 429 waveforms to customize decode readout
  • Correlate analog waveforms with protocol decode on one screen
  • View decoded data in binary, hexadecimal, decimal or symbolic format
  • Decode information expands as the time base is adjusted or zoomed
  • Convenient table display with quick "Zoom to byte" capability
  • Quick search capability for specific message packets
The Most Intuitive Decode
The ARINC 429 Symbolic decode uses uses color-coded overlays on various sections of the protocol for an easy-tounderstand visual display. Depending on the time base or the amount of zoom, the decode information is condensed or expanded to better assist in understanding events during short or long acquisitions.
Symbolic Decodes Speaks Your Language
ARINC 429 Dsymbolic option decodes ARINC 429 serial data into symbolic (Application layer) text directly on the oscilloscope display. The user defined file converts the decoded hex, binary, hexadecimal, or decimal values into a label defined by the ARINC 429 system.
The Single Tool Enhances Productivity
The ARINC 429 Dsymbolic solution concentrates all your information in one place. Viewing the application layer of ARINC 429 signals on top of the physical layer provides a unique view that bus analyzers cannot. Measurements such as amplitude and rise time help to debug physical layer issues that may not be apparent in a protocol view.
Symbolic Decoding
ARINC Dsymbolic provides a unique and powerful way to view decoded data. Using a user provided file, the label and equipment ID fields can be displayed to match the user provided file, showing an easier to interpret protocol display.
Convenient Table Display Summarizes Results
Turn your oscilloscope into a protocol analyzer with the table display of protocol information. Custom configure the table to display the information you want, and export table data into an Excel file. Touch the message in the table and automatically zoom for detail. In all cases, the table never obscures your waveform.
Search and Zoom
Search through a long record of decoded data by entering any of the 14 available search criteria by entering a value or simply finding the next occurance.
关键词: ARINC     总线
