电子产品世界 » 论坛首页 » 企业专区 » TI » 【技术应用】创作有了一个固定占空比的脉冲宽度调制信号
2012-04-14 00:10:20     打赏
摘要:
This document explains how the EVM Application #1 generates a Pulse Width Modulated (PWM) signal and includes the following information. - An overview, background and methodology on what the EVM Application #1 is and how it works. - Listing of the three modules which must be configured - Formula for performing period register and compare register value calculations. - A figure that shows the difference between active high and active low polarity. - Assembly code for generating a pulse width modulated signal for the target system, the Texas Instruments (TI)(tm) TMS320F240 Evaluation Module (EVM).
文档:spra410.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=spra410
关键词: 技术应用     创作     有了     一个     固定     占空     比的     脉冲
