电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Measuring Temperature with the MAX1358 D
Measuring Temperature with the MAX1358 Data Acquisition System
2012-04-14 19:30:57     打赏
关键词: MAX1358, MAX1359, MAX1360, Medical, Temperature
Abstract: This application note explains how to use the internal and external temperature sensors on the MAX1358 data acquisition system. The temperature circuits for the MAX1358/MAX1359/MAX1360 are identical, therefore any reference to the MAX1358 also applies to the MAX1359 and MAX1360. A step-by-step approach guides the user through the setup, measurement, and calculation of the temperature.
 Measuring Temperature with the MAX1358 Data Acquisition System.pdf
关键词: Measuring     Temperature     MAX
