电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » 力科USB 3.0解决方案
共4条 1/1 1 跳转至
力科USB 3.0解决方案
2012-04-15 11:19:37     打赏
USB 3.0 bus USB3.0解码软件包选项提供链路层的解码功能,并将解码后的信息显示在USB3.0物理层波形上。这使得在示波器上能够查看协议数据,并确认该连接是否正常运作,传输正确。它也能帮助调试那些并非纯粹模拟或数字信号的问题,比如互操作性问题,不确定的错误原因,以及物理层上不明显的问题。
Voyager M3i
The Voyager M3 is LeCroy’s 6th generation USB protocol verification platform designed for the next evolution of universal serial bus known as SuperSpeed USB. Leveraging LeCroy’s extensive expertise in high-speed serial data analysis, the Voyager provides 100% accurate protocol capture of both USB 2.0 and 3.0 at data rates up to 5 Gb/s.
LeCroy has developed six generations of its industry leading USB protocol verification system since the introduction of USB in 1995. Each successive generation of the LeCroy USB analyzer family has built upon the previous knowledge and expertise. Today, LeCroy offers a broad range of USB test systems with unprecedented functionality, accuracy and user friendliness. The enormous cost of discovering problems after a product is released far outweighs the investment in LeCroy's de-facto standard USB analysis tools. Their use improves the speed and efficiency of the debug, test and verification for USB semiconductor, device, and software vendors. Analyzers or bus "sniffers" also play an essential role in avoiding costly interoperability problems by allowing developers to verify compliance with the USB specification.
Consistent with the growing popularity of digital media, the USB-IF announced USB 3.0 in late 2007 targeting 10X the current USB bandwidth by utilizing two additional high-speed differential pairs for "SuperSpeed" transfer mode. The USB 3.0 specification was released in late 2008 and commercial products began shipping in late 2009. LeCroy has pioneered the development of verifications systems for this new technology. The only company that offers a complete line of USB 3.0 test solutions covering transmitter test to protocol test, and every step in between, LeCroy helps developers achieve their goals of performance, quality, reliability and time-to-market for SuperSpeed technology.
USB Technology Overview:
USB, or Universal Serial Bus, is a connectivity standard that enables computer peripherals and consumer electronics to be connected to a computer without reconfiguring the system or opening the computer box to install interface cards. The USB 1.0 specification was introduced in January 1996. The original USB 1.0 specification had a data transfer rate of 12 Mbit/s The first widely used version of USB was 1.1, which was released in September 1998. It provided 12 Mbps data rate for higher-speed devices such as disk drives, and a lower 1.5 Mbps rate for low bandwidth devices such as joysticks. USB 2.0 specification was released in April 2000 and was ratified by the USB-IF at the end of 2001 to develop a higher data transfer rate, with the resulting specification achieving 480 Mbit/s
USB today provides a fast, bi-directional, low-cost, serial interface that offers easy connectivity to PCs. A hallmark for USB operation has been the ability for the host to automatically recognize devices as they are attached and install the appropriate drivers. With features such as backward compatibility with previous devices and hot "plug-ability", USB has become the de-facto standard interface for various consumer and PC peripheral devices. The USB standard allows up to 127 devices connected to a Host System. USB designates low, full, high-speed connectivity between devices compatible with the 2.0 specification. Most full speed devices include lower bandwidth mice, keyboards, printers, and joysticks. The use of high speed USB has exploded with the rapid growth in digital media in the consumer electronics market including media players, digital cameras, external storage and smart phones.
SuperSpeed USB is designator for links operating at the 5 GHz frequency and compatible with the USB 3.0 specification. SuperSpeed USB provides a high performance connection topology for applications that utilize larger files or require higher bandwidth. SuperSpeed USB is backward compatible with USB 2.0, resulting in a seamless transition process for the end user. SuperSpeed USB offers a compelling opportunity for digital imaging and media device vendors to migrate their designs to higher performance USB 3.0 capable interface.
NEC/Renesas was the first chip vendor to introduce host controllers for USB 3.0 (5/18/2009). The first motherboards featuring USB 3.0 ports from Asus and Gigabyte followed in late 2009. In the first half of 2010, dozens of SuperSpeed devices began shipping as vendors rushed to deliver solutions using the 5Gbps signaling speed of USB 3.0. Expect mass adoption into high-bandwidth applications in late 2010.
Why USB?
From its emergence in 1995 as a low-cost connection interface for keyboards and mice, USB has steadily expanded its presence in computing and consumer electronics to become the most popular peripheral interconnect in history. USB continues to be dominant for the following reasons:
  • Mature, proven technology
  • Backward-compatible and low cost
  • Easy plug and play operation
  • Data transfer speeds suitable for a variety of applications
As evidenced by USB popularity, several extensions of the technology have been introduced to try and capitalize on its installed base/ popularity. An example of this extension, which is supported and approved by the USB Implementers Forum (USB-IF), is USB On-The-Go (OTG). Designed to allow portable computing devices, such as cell phones and digital cameras, the ability to connect to other USB devices as either a host or peripheral, OTG promises improved interoperability for an enormous number of USB enabled devices.
In addition, there are now dozens of USB device classes addressing everything from health care systems to isochronous video applications. Mass storage remains one of the most popular USB applications as consumers have embraced all types of digital media. The T10 committee has now finalized USB Attached SCSI (UAS) protocol which enables several significant improvements over legacy mass storage protocols including command queuing and streamed IO. Of particular interest is the new battery charging specification which provides a standard mechanism allowing devices to draw current in excess of the USB specification when connected to wall chargers or fast charging host controllers. In addition to the traditional data interchange application, the battery charging specification has solidified USB's dominant role as the interface of choice in the portable electronics market.
USB Architecture
USB was initially introduced as a host to peripheral interconnect with the goal of putting most of the intelligence on the host-side. The OTG specification added an optional peer-to-peer capability to devices but had limited adoption to date. So the vast majority of USB devices typically fall into 2 categories:
  • Hosts
    • PCs, Macs and laptops
  • Peripherals
    • All devices designed to attach to a host (examples)
The role of the host controller (plus software) is to provide a uniform view of IO systems for all applications software. For the USB IO subsystem in particular, the host manages the dynamic attach and detach of peripherals. It automatically performs the enumeration stage of device initialization which involves communicating with the peripheral to discover the identity of a device driver that it should load, if not already loaded. It also provides device descriptor information that drivers can use enable specific features on the device. Peripherals add functionality to the host system or may be standalone embedded operation. When operating as a USB device, peripherals act are slaves that obey a defined protocol. They must react to requests sent from the host. It's largely the role of PC software to manage device power without user interaction to minimize overall power consumption. The USB 3.0 specification redefines power management to occur at the hardware level with multiple power states designed to reduce power usage across the IO system.
Links
The Voyager M3 is LeCroy’s 6th generation USB protocol verification system designed for the next evolution of universal serial bus known as SuperSpeed USB. Leveraging LeCroy’s extensive expertise in high-speed serial data analysis, the Voyager provides 100% accurate protocol capture of both USB 2.0 and 3.0 at data rates up to 5 Gb/s.
This multifunction validation platform is available with an integrated exerciser capable of both 2.0 and 3.0 host and device emulation. In addition to error injection and compliance verification, the exerciser provides early adopters with a USB 3.0 link to begin bring-up testing well before commercial hosts are available. Loaded with innovative features that anticipate the needs of early adopters, the Voyager platform is the intelligent choice for "cradle-to-grave" USB 3.0 validation.
Voyager USB 3.0 Introduction series of video demos
  Title Time
Chapter 1: Recording & Triggering 8:01
Chapter 2: Part 1: Advanced Triggering 6:28
Chapter 2: Part 2: Advanced Triggering 6:22
Chapter 3: Troubleshooting Connection Issues 8:09
Chapter 4: Introduction Packet & Header Display Options 8:24
Chapter 5: Compliance Suite - Part 1 8:27
Chapter 6: Compliance Suite - Part 2 9:39
Unmatched Accuracy
The Voyager analyzer front-end leverages custom circuitry from LeCroy’s 5Gb/s PCI Express analyzer to provide fast-locking and uncompromised accuracy for USB 3.0 recording. SuperSpeed USB will implement hardware based power management with devices frequently entering power suspend mode. While in-line, the Voyager system will detect and seamlessly recover from electrical idle while accurately showing all bus and power state transitions time-stamped within the display. It includes full support for spread spectrum clocking (SSC) and data scrambling (LFSR) which can be enabled / disabled for silicon bring-up testing.
Flexible hardware
The front end of the Voyager analyzer features native 3.0 connectors that bifurcate USB 2.0 and 3.0 electrical signals to provide loss-less capture of traffic from both links simultaneously. Concurrent high-speed and SuperSpeed recording allows end-to-end viewing of data transfers across a USB 3.0 hub. The system can operate as a USB 2.0/3.0 analyzer; and is also available in a 2.0-only configuration that is upgradeable to 3.0.
The Voyager M3 platform includes 4GB of recording memory plus USB and Gbe links for uploading recorded traffic to the host PC. Fast access to captured traffic is now possible thanks to sustained data transfers of 600Mbit per second over the Gbe link. Both the analyzer and exerciser can utilize slow clocking (fractional) or external clock sources (as low as 1Mhz) for testing with FPGA-based prototypes or emulators that require ultra low-speed data acquisition. More
The heart of the Voyager verification system is LeCroy’s revolutionary BusEngine? technology. This state-of-the-art protocol processing core incorporates a real-time recording engine and configurable tools to selectively monitor and record SuperSpeed USB traffic. Field upgradeable firmware allows the BusEngine to evolve and support new features or future changes to the USB specification.
Additional innovations include upgradeable hardware components. The USB connectors on the analyzer are mounted on a removable daughter-card allowing the system to be upgraded as improved connectors are available. The analyzer and exerciser also include SMA differential Input/Output lines as an alternate interface for taping between early development boards. This eliminates dependencies on USB 3.0 connectors allowing testing to begin as soon as PHY silicon is available.
6th Generation Analysis Software
The Voyager utilizes the legendary CATC Trace which has become the industry’s de facto standard for USB 2.0 protocol analysis. The trace viewer software uses colors and patterns to train the eye to understand information faster. When recording mixed traffic upstream from a SuperSpeed hub, Legacy 2.0 and 3.0 packets are labeled and interleaved in a single display. Each event is shown on a separate row with every field labeled and color coded.. Traffic from the logical 2.0 & 3.0 channels can be individually filtered, searched or exported from the trace. The USB Transfer level can be expanded and collapsed to show the packet layer including all link management packets (LMPs) and flow control symbols.
Raw Debugging Power
The Voyager includes a special Link Tracker mode that captures every transition and presents raw 10-bit data patterns chronologically with timing resolution of 2ns. Designed to assist with low-level debugging, all ordered sets including training sequences and inter-packet symbols can be displayed in raw 10-bit, 8-bit, scrambled, and unscrambled Hex format. Symbol-to-symbol timing measurements are possible with a single click.
Key Features
  • CATC Trace Analysis Software System ¨C Expand / Collapse transfer layer for faster interpretation of USB traffic
  • Capture / Analyze 3.0 & 2.0 traffic concurrently ¨C Record 2.0 and SuperSpeed data path to test & debug USB 3.0 host & hub operation
  • Integrated 3.0 analyzer / exerciser (single box) ¨C Multifunction system with 3.0 and 2.0 device or host traffic generation
  • 4GB Recording Capacity - Capture long recording sessions for analysis and problem solving
  • Raw bit Recording / 10-bit error detection ¨C view and correlate low-level 10-bit symbols to higher-level packet structures
  • Detects over 40 Link & Protocol errors ¨C Critical link and timing errors are automatically detected and flagged in the trace
  • 2ns timing resolution - extremely accurate timing resolution allows precise measurement of link layer handshaking
  • External Trigger In / Out ¨C Use the LeCroy Voyager to identify any packet and toggle a scope or logic analyzer (via SMA connectors)
  • Fully supports SSC and Data scrambling - Fast Locking and Accurate capture on 5Gbps signals
  • Hardware Triggering ¨C Trigger on both 2.0 or 3.0 protocol events to isolate important traffic, specific errors or data patterns
  • Comprehensive Device Decoding - SCSI Mass Storage, 3.0 Hub, PTP/Still Image, Printer, PictBridge, Media Transfer Protocol (MTP), and all popular USB device classes
  • Hardware Filtering - Automatically exclude non-essential and redundant symbols including Idles, TS1, TS2, SKPs, and LFPS sequences.
  • Intelligent Reporting - Automatically report event metrics and flag over 20 common USB 3.0 protocol errors
  • Sophisticated Viewing - View TLP messages and headers, plus logical transaction and transfer layers of the USB protocol
  • Gbe or Hi-Speed USB upload ¨C Sustained transfer rates of 600Mbps over Gbe provide instant access to captured data
  • SMA-input differential probing - alternate connector interface allows taping between early development boards if native connectors are unavailable More
  • Slow clock / External clock Input ¨C Adjustable signal frequencies for synchronizing analyzer timing with prototype & validation boards
  • Loopback and Compliance Mode ¨C Exerciser system provides special console for initiating loopback and compliance mode
  • Link Training and Timing Views - LTSSM flow diagram and chronological views linked to trace display
  • Power Tracker? Option - Graphs Power & Current draw for VBus devices synchronized to the trace data
  • 3 Year Hardware Warranty - Protect your investment with industry leading support and warranty
Intelligent Triggering
The Voyager provides hardware triggering to pinpoint protocol events of interest. Trigger events can be specified at the lowest levels including bus states and ordered sets (Link up, SKP, etc¡­) or header fields including route strings or packet types (ACK, EPRDY, etc¡­.). Voyager’s graphical drag-and-drop interface makes setup easy. Users can define trigger logic that monitors multiple sequential event trigger scenarios that include SCSI operations, counters, loops and timers all within a multi-level sequence.
Real Time Filtering
SuperSpeed data transfers at 5 Gb/s can fill memory buffers in an instant making event filtering critical for efficient debug. The Voyager analyzer can filter unwanted traffic from the buffer in real-time by discarding redundant patterns such as SKPs, idles, and training sequences. Filtering logic can also include transaction layer packets with added criteria like direction or port number.
Error Detection
The LeCroy Voyager can detect and flag real protocol errors including logical link and timing errors. At the lower layers, training sequences and link commands are automatically verified for proper formatting. The Spec View displays header fields in hex or binary and also marks errors in red.
Integrated Exerciser Option
A comprehensive exerciser capability with support for both USB 2.0 and 3.0 traffic generation is built in to the Voyager platform. The exerciser option allows users to transmit custom packets over standard USB cables with low-level control of headers, payloads, timing, and link states. Featuring Voyager ReadyLink? and Transaction Engine? the exerciser includes full function link and transaction layer state machines that automatically handle all USB 3.0 handshakes. ReadyLink maintains link synchronization, flow control and header acknowledgements. The Transaction Engine manages NRDY retry conditions allowing the Voyager to operate at full line rate and correctly respond to the DUT as defined by the specification. . Overrides allow these behaviors to be altered such as shortening LFPS and link training signals, or delaying handshake packets. The Exerciser is seamlessly integrated with the Protocol Analyzer, making the Voyager system a complete test and development solution for engineers validating USB protocol. More
USB Device Decoding
The Voyager software performs full decoding of USB device class traffic with both automatic and manual assignment of decodes to individual endpoints. The Voyager offers full support for Bulk Only Transport and USB Attached SCSI operations including command queuing. From OTG, to CCD, to Video class, Voyager provides the most comprehensive decoding available. It also supports vendor specific decoding for developers interested in automatically showing proprietary commands in the trace view.
Complete list of USB Decodes (Click to Expand ¡ý)
  • Mass Storage - SCSI (SPC-2)
  • Mass Storage - ATAPI (MMC-2)
  • Mass Storage - RBC (R10A)
  • Hub Class
  • Hub Notification
  • Printer Class
  • Communication Class
  • Communication Notification
  • Communication Class with AT Command
  • Communication Class with PPP
  • Bluetooth HCI Command
  • Bluetooth HCI Event
  • Bluetooth ACL Packet
  • Bluetooth SCO Packet
  • HID Class
  • Audio Class Descriptor
  • Audio Class Request
  • CCID Class Request
  • CCID - Command
  • CCID - Event
  • CCID - Data/Response
  • CDC - HDLC - Command
  • CDC - 1430 - Command
  • CDC - Q931 - Command
  • CDC - Q921M - Command
  • CDC - Q921 - Command
  • CDC - Trans - Command
  • CDC - V.42bis - Command
  • CDC - Event
  • CDC - Class Descriptor
  • CDC - Class Request
  • Firmware - Class Request
  • Firmware - Class Descriptor
  • HID Class Descriptor
  • HID Class Request
  • Mass Storage Class Request
  • MTP - Class Req.
  • MTP - Command
  • MTP - Data/Resp.
  • MTP - Event
  • PPP - Ethernet Receive
  • PPP - Ethernet Send
  • SCSI- MMC4 - Bulk Only
  • SCSI - MMC4 - CBI
  • SCSI - RBC - CBI
  • SCSI - SBC - Bulk Only
  • SCSI - SBC - CBI
  • SCSI - SPC2- CBI
  • SCSI - SPC3 - Bulk Only
  • SCSI - SPC3 - CBI
  • SCSI - SSC - Bulk Only
  • SCSI - SSC - CBI
  • Still Image (Cmd.Data. Resp)
  • Still Image Class Req.
  • Still Image Command
  • Still Image Data/Response
  • Still Image Event
  • USB Attached SCSI Protocol (UASP)
  • USBTMC - Command
  • USBTMC - Response
  • USBTMC - Event
  • Video - Cameras Terminal - Class Req.
  • Video - Video Streaming - Class Req.
  • Video - Descriptor
  • Video - Event
  • Video Payload Descriptor
  • Video Payload
  • Video Processing Units - Class Request
  • Video Selector Units - Class Req.
  • Video Transport
  • Video - Video Control Interface - Class Req.
  • WUSB - DWA - Descriptor
  • WUSB - HWA - Descriptor
  • WUSB - HWA - DWA Request
Find The Issues Fast
The Voyager software provides many mechanisms to measure and report on USB 2.0 and 3.0 protocol. With the Traffic Summary display, users can evaluate statistical reports at a glance or navigate to individual events. Users may select transaction packets to view ACK/NAK or Device Notification events, then jump to each occurrence with a single keystroke. Reports are available showing link throughput and flow control metrics. Higher level events are also tracked and reported at the logical USB Transfer level. The error report shows a range of protocol violations - from invalid CRCs to framing errors.
The LTSSM View provides an interactive USB 3.0 state machine diagram. Each state change is shown graphically and is hyperlinked to the trace display. The link state timing view shows the same information in a time-line format.
Bus Utilization graphs show data and packet length, bus usage by device in a histogram format. The Bandwidth calculator automatically calculates the time delta between two points in the trace. Fast Search and Find options allow users to navigate to specific packets, errors and any data type within a trace file. The CATC Trace supports filter and hide commands, to temporarily remove irrelevant data from the display for more efficient viewing.
Optimize vBus efficiency with PowerTracker?
The Voyager M3i Power Tracker option offers a unique monitoring capability for Vbus power draw. Power information is sampled and displayed graphically in a time line format and is synchronized to the trace allowing users to verify power state transitions at the protocol and electrical layers. More
Since 1996, LeCroy has been a key provider of tools for the USB ecosystem. The Voyager system leverages countless hours of research in high-speed serial data analysis to create the most reliable and accurate USB 3.0 analyzer system available. Combined with the exerciser option and the CATC Trace expert software, the Voyager platform alleviates developers from tedious byte-level analysis and lets them focus on quick resolution of protocol layer problems.
关键词: 力科     解决方案     Voyager     protocol
2012-04-15 11:24:52     打赏
USB 3.0 Test Suites
One of the most highly anticipated new standards in many years, SuperSpeed USB (USB 3.0) is the next advance for the widely adopted Universal Serial Bus (USB) standard. The key performance upgrade of SuperSpeed USB is an increase in the data rate from 480Mb/s to 5 Gb/s--ten times faster than USB 2.0. However, the higher speed and more complex features create more complicated signals that require more sophisticated measurement and analysis. Developers face additional requirements in the new specification that blur the boundaries between physical layer testing and protocol layer testing. LeCroy’s leadership in oscilloscope and protocol analyzer technology, serial data expertise, and tradition of innovation, ensures a complete suite of SuperSpeed USB test solutions that address today’s challenges and anticipate increasingly integrated test methodologies.
Comprehensive Verification, Debug and Compliance
Successful development of new USB 3.0 products requires a coordinated test program, running from transmitter testing (to verify eye diagrams, jitter, and other performance measurements), to receiver testing (to ensure reliable data transfer), to TDR testing (to ensure reliable channels, PCB designs, connectors and cables), and finally to protocol testing (to ensure functionality and compliance to USB 3.0 requirements).
Single Vendor Solution
LeCroy is the only company that offers a complete line of USB 3.0 test solutions covering transmitter test to protocol test, and every step in between for comprehensive verification, debug and compliance. SuperSpeed USB test needs are supplied with a single point of procurement and support. Further, LeCroy provides uniquely integrated test solutions that combine test capabilities at multiple levels and merge the results for more accurate and meaningful information. LeCroy’s experience and leadership in providing high-speed serial data test tools make LeCroy the natural choice as a test partner for SuperSpeed USB development.
LeCroy’s test tools cover the full range of test needs: industry-leading oscilloscopes for transmitter testing, unique products such as the Protocol-enabled Receiver and Transmitter Tolerance Tester (PeRT3™), specialized solutions for TDR testing on sampling oscilloscopes, and a full line of serial data protocol analyzers. Our test tools are not only superb in their own test areas, but because they are well integrated with each other, they help engineers easily move test designs and results from one LeCroy system to another providing quicker and deeper insight for confidence in measurement results.
The Right Support for Every Stage of Development
The PeRT3 Test System, which integrates receiver test with protocol-awareness, provides the ability to automate testing through active control of the device under test, and to integrate diverse test results from multiple levels. It is also able to easily manage through protocol issues such as SKP symbols which can interrupt testing on competitive products.
QualiPHY, LeCroy’s automated test engine, is the only solution that fully integrates and automates transmitter and receiver testing. QPHY-USB3-Tx-Rx permits the scope to communicate directly with the PeRT3 automating both instruments and creating compliance reports that include both transmitter and receiver results.
LeCroy provides the right tools for you every step of the way. Our coordinated solutions guide you through the most difficult engineering and development tasks and help ensure product goals of performance, quality, reliability and time-to-market are all met.
About SuperSpeed USB
Developed and promoted through the USB Implementers Forum (USB-IF), USB has been long established as the interconnect system of choice for peripheral systems.
SuperSpeed USB is backwards compatible with USB 2.0, ensuring a smooth adoption path for all users. However, for developers the challenges of USB 3.0 are daunting. High-speed gigabit serial data links require new design approaches, high quality manufacturing processes, and comprehensive testing and debug procedures to achieve reliable data transfer and interoperability. The SuperSpeed USB Compliance Test Specification requires the use of reference channels and continuous time linear equalization (CTLE) for compliance measurements. The SDA 813Zi with the Eye Doctor™ II analysis package has the ability to emulate the reference channel and the CTLE as specified for both compliance measurements and to troubleshoot the root cause of compliance failure.
Another of the new SuperSpeed USB capabilities is Optimized Power Management which requires all devices to actively manage power (sleep states, etc.). The development and test of this feature requires equipment that is able to simultaneously monitor both physical and protocol levels.
The Power Tracker option for the Voyager™ USB 3.0 Protocol Analyzer simultaneously captures both protocol traffic and power consumption, allowing engineers to quickly isolate and identify problems in ensuring compliance to the new power management requirements.
SDA 8 Zi-A Series Serial Data Analyzer
The SDA 8 Zi-A Serial Data Analyzers are based on the WaveMaster 8 Zi-A Series oscilloscope and are equipped with double the standard memory to capture more unit intervals in the eye diagram. They include an enhanced high-speed serial pattern trigger that operates on up to 80 bit patterns and at speeds up to 3.125 Gb/s. Whether debugging eye pattern or other compliance test failures, the SDA 8 Zi-A Series rapidly isolates the source of the problem in your design. For USB 3.0 applications, the recommended model is the SDA 813 Zi equipped with the QualiPHY Enabled USB 3.0 and the Eye Doctor II software options.
QualiPHY Automated Compliance Testing
QualiPHY is designed to reduce the time and effort needed to perform compliance testing on a wide array of high-speed serial buses. QualiPHY is the most intuitive and efficient tool available for performing serial data compliance testing. Selecting a new standard or test setup is done without leaving the main screen, and the user can start testing with a single button press. For USB 3.0 applications, the recommended version is the QualiPHY Enabled USB 3.0 Software Option.
PeRT3 Test System
The PeRT3 (Protocol-enabled Receiver and Transmitter Tolerance Tester) fills the space between physical layer test and protocol test, providing a new and more intelligent capability for performance testing of receivers and transmitters. Designed to meet the test needs of engineers working with serial data transceivers and other high-speed serial data communication systems, the LeCroy PeRT3 Test System is not just a new instrument, it is an entirely new instrument class. For USB 3.0 applications, the recommended model is the PeRT3 Eagle R6-8 Platform with PeRT3 Eagle R6-8 1-Channel Front End, equipped with the Eagle USB 3.0 Receiver Test Suite.
SPARQ Signal Integrity Network Analyzer
The LeCroy SPARQ is a new class of instrument; the Signal Integrity Network Analyzer. SPARQ, which stands for "S-parameters Quick", is a TDR/TDT-based analyzer that measures 40GHz, 4port S-parameters with a single button press, and at a fraction of a cost of a VNA. Fully calibrated measurements can be made in minutes, and without any need to connect or disconnect cables to calibration kit standards or electronic calibration modules.
Voyager Protocol Analyzer
The Voyager M3 is LeCroy's 6th generation USB protocol verification platform, designed specifically for USB 3.0 applications. Leveraging LeCroy's extensive expertise in high-speed serial data analysis, the Voyager provides 100% accurate protocol capture of both USB 2.0 and 3.0 at data rates up to 5 Gb/s. For USB 3.0, the recommended models are either the Voyager USB 3.0 Pro Analyzer System or the Voyager USB Pro Analyzer/Exerciser System.
USB 3.0 Test Suites - Ordering Information
2012-04-15 11:26:37     打赏
QPHY-USB3-Tx-Rx
SuperSpeed USB is one of most highly anticipated standards in several years. At 10x the data rate of USB 2.0 and with new features like CTLE (continuous time linear equalization) and reference channels, SuperSpeed USB will pose new challenges to implementers.
Key Features
  • QPHY-USB3-Tx-Rx supports all transmitter compliance tests as described by the SuperSpeed USB Electrical Compliance Test Specification (Rev 0.9), and selected tests in accordance with the Universal Serial Bus 3.0 Specification
  • Complete automation of physical layer transmitter and receiver testing
  • SIGTEST electrical test software is fully integrated into the oscilloscope software
  • QPHY-USB3-Tx-Rx provides full reporting capability including Pass/Fail indications and screen - shots from pertinent tests
  • Eye Doctor™ II Advanced Signal Integrity Tools enable channel emulation and equalization which aids in debugging SuperSpeed USB compliance failures
  • SDA II allows fast eye diagram creation and jitter analysis on long memory acquisitions
SuperSpeed USB is one of most highly anticipated standards in several years. At 10x the data rate of USB 2.0 and with new requirements like CTLE (continuous time linear equalization) and reference channels, SuperSpeed USB will pose new challenges to implementers.
QPHY-USB3-Tx-Rx is an automated test package for SuperSpeed USB compliance testing. It provides connection diagrams to ensure the proper setup for the required measurements, automates the oscilloscope for performing these measurements, and provides a comprehensive report of results including screenshots.
The LeCroy SDA 8 Zi Series of oscillo scopes with the Eye Doctor? II analysis package are the perfect instruments for performing SuperSpeed USB compliance measure ments and more importantly for debugging compliance failures allowing the engineers to quickly find the root cause of serial data problems.
SDA II allows the user to quickly create eye diagrams utilizing the full record length of the oscilloscope and perform jitter analysis accurately, even when there is very long nonrepeating pattern jitter decomposition. This is critically important for properly distinguishing between random and deterministic jitter in systems containing a channel that severely stresses the signal.
Additionally, Eye Doctor II provides the channel emulation and de-embedding tools that engineers need for next generation serial data standards.
QPHY-USB3-Tx-Rx uses all of these oscilloscope features to perform the compliance tests as described by the USB 3.0 Electrical Test Specification.
The LeCroy QPHY-USB3-Tx-Rx automated test solution is the only solution that fully integrates transmitter and receiver testing into one test suite.
Using the LeCroy Protocol-enabled Receiver and Transmitter Tolerance Tester (PeRT3), QPHY-USB3-Tx-Rx has the ability to perform all of the SuperSpeed USB receiver tests as described by the SuperSpeed USB specification. Also, the PeRT3 can connect to the device under test, set the device to output the proper test pattern or enter loopback mode and output the proper test pattern. Then QPHY-USB3-Tx-Rx uses the SDA 813Zi oscilloscope to perform all of the SuperSpeed USB transmitter measurements as described by the SuperSpeed USB specification. All of this can be done simply with the push of a button.
Using the TF-USB3 and the RF Switch, the transmitter output of the product under test can be switched between either the PeRT3 input or the oscilloscope input. Additionally, the transmitter output of the PeRT3 can be switched between either product under test or the oscilloscope. Finally, the compliance test channel, which is required for receiver testing, can be put in the path from the PeRT3 to the product under test. This enables all of the transmitter tests and the receiver tests to be performed with one setup. No connection changes are required.
Additionally, since all of these tests are run from QPHY-USB3-Tx-Rx, the results of the transmitter test as well as the receiver results can be created in one comprehensive report.
Finally, everything required for SuperSpeed testing can be ordered with LeCroy’s SuperSpeed USB Bundles. For additional information on LeCroy’s SuperSpeed USB Bundle Options please visit ww.lecroy.com.
The Eye Doctor II analysis software allows the user to view their signal after Continuous Time Linear Equalization (CTLE). QPHY-USB3-Tx-Rx uses this functionality to create the eye diagram and measure the jitter after CTLE as required by the SuperSpeed USB Compliance Specification.
LeCroy’s SDA II analysis software contains integrated jitter and timing analysis for clock and data signals. It allows analysis of data up to the memory limit of the oscilloscope and using X-Stream II technology, SDA II can display eye diagrams and jitter decomposition results up to 50 times faster than other solutions. Additionally, the specific PLL for SuperSpeed USB is selectable from a list of pre-configured PLLs. Lastly, SDA II can accurately measure jitter when there is a very long repeating pattern as is used in the USB3 by taking advantage of its very long memory or using a method that does not require the pattern to repeat allowing for measurements or small acquisitions.
Additionally, the Eye Doctor II analysis software also enables channel emulation. For USB 3.0 testing, a design engineer will perform their serial data measurement at the output of the transmitter. However, the specification requires that the measurements be made at the far side of a reference serial data channel. To accomplish this they could either use a physical channel to make their measurement after the channel or they can use channel emulation to see what their serial data signal would look like if it had been transmitted through the channel.
QPHY-USB3-Tx-Rx utilizes this functionality to automatically emulate the reference compliance channel prior to eye diagram and jitter testing.
QPHY-USB3-Tx-Rx Test Coverage
  • Template Test (Eye Diagram)
  • Total Jitter
  • Deterministic Jitter
  • Random Jitter
  • SSC Modulation Rate
  • SSC Modulation Deviation
  • Pk-Pk Differential Voltage
  • Low Power Pk-Pk Differential Voltage
  • Unit Interval
  • SSC Slew Rate
  • De-emphasis Voltage Ratio
  • Transmitter Min Pulse
  • DC Common Mode Voltage
  • AC Common Mode Voltage
  • LFPS tPeriod
  • LFPS tBurst
  • LFPS tRepeat
  • SIGTEST Integration
  • Integrated Receiver Testing using the LeCroy PeRT3
2012-04-15 11:27:50     打赏
ProtoSync
The ProtoSync option further leverages the supported LeCroy decode annotation options (PCIEbus D, USB2bus D, USB3bus D, SASbus D, SATAbus D, and Fcbus D) installed on the oscilloscope.
ProtoSync is an option for LeCroy oscilloscopes that provides simultaneous views as follows:
  1. Physical layer waveforms (captured by a LeCroy oscilloscope)
  2. Decode annotation overlays (displayed on a LeCroy oscilloscope)
  3. Protocol analysis views (displayed in a separate software window)
The ProtoSync option further leverages the supported LeCroy decode annotation options (PCIEbus D, USB2bus D, USB3bus D, SASbus D, SATAbus D, and Fcbus D) installed on the oscilloscope. It provides the ability to export the physical layer waveform data to a separate LeCroy protocol analysis software package (the same package that provides protocol analysis views when used with a LeCroy hardware protocol analyzer), and it synchronizes the data displays between the oscilloscope and protocol analysis software package. Selecting a specific portion of the decode annotated physical layer waveform on the oscilloscope will automatically select the corresponding protocol analysis software packet display, or vice-a-versa. Thus, debug and analysis using a variety of views is very easy.
ProtoSync is especially useful for standards that support dynamic equalization (PCI Express Gen3, and forthcoming versions of SAS). Dynamic equalization is a link initialization process where training sequences communicate transmitter and receiver parameters to establish a link. In the pre-silicon stage of development, protocol analyzer hardware may not yet be available or physical layer problems may be so prevalent that a protocol analyzer may not be able to provide the desired analysis. Yet debugging dynamic equalization is usually much easier if both analog waveforms and high level protocol packet data are available and are synchronized together so as to navigate to hard-to-find details of dynamic equalization.
In addition, more mature standards (PCI Express Gen1, SATA 1.5 Gb/s, etc.) are increasingly becoming embedded in system designs. Embedded systems usually present complex attachment or probing challenges that make it difficult to conveniently connect a protocol analyzer, or the embedded system engineer may not be familiar with the protocol analyzer tool. However, the challenges around connecting an oscilloscope to the embedded system are usually already known and resolved, and the debug and validation system engineer is quite familiar with the operation of an oscilloscope. By providing the ability to view advanced protocol packet data using physical layer oscilloscope captures as a source, complex problems can be more easily debugged.
ProtoSync runs on LeCroy WaveRunner, WavePro, and WaveMaster platforms.
共4条 1/1 1 跳转至
