电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Effective Number of Bits Calculator Tuto
Effective Number of Bits Calculator Tutorial
2012-04-15 21:07:20     打赏
关键词: Effective Number Bits, Calculator, ENOB, Data Converter, SINAD, Resolution, Signal, Oversample Rates, DNL, Clock, Jitter, Analog Noise, THD, ADC, DAC, Analog Design, Digital Accuracy, HP50g, INL, Total Harmonic Distortion
Abstract: The Effective Number of Bits Calculator (ENOB) aids in the design and analysis of data converter application circuits. It calculates ENOB, SINAD, resolution, signal bandwidth, oversample rates, DNL, clock jitter, analog noise, and THD. The calculator can be used with a HP® 50g calculator or a free PC emulator.
 Effective Number of Bits Calculator Tutorial.pdf
关键词: Effective     Number     Calculat
