电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Design a Low-Jitter Clock for High-Speed
Design a Low-Jitter Clock for High-Speed Data Converters
2012-04-16 21:23:55     打赏
关键词: high-speed ADCs, high-speed analog to digital converter, PLL, VCO, phase-locked loop, voltage-controlled oscillator, low phase noise, low phase jitter, clock jitter, crystal oscillator, noise, SNR, spurious components, analog digital, data converters
Abstract: High-speed applications using ultra-fast data converters in their design often require an extremely clean clock signal to make sure an external clock source does not contribute undesired noise to the overal dynamic performance of the system. It is therefore crucial to select suitable system components, which help generate a low phase-jitter clock. The following application note serves as a valuable guide for selecting the appropriate components to design a low-phase noise PLL-based clock generator, suitable for ultra-fast data converters.
 Design a Low-Jitter Clock for High-Speed Data Converters.pdf
关键词: Design     Low-Jitter     Clock     H
