电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » High-Side Current Sensor Has Period Outp
High-Side Current Sensor Has Period Output
2012-04-22 15:11:51     打赏
关键词: current sense IC, high side current sense, current sense amplifier, pulse width signal output, current sense resistor
Abstract: The MAX4374 high-side current sense amplifier with two internal comparators is used to produce a pulse-width output signal proportional to the current being sensed. This simple circuit eliminates the need for a discrete A/D converter.
 High-Side Current Sensor Has Period Output.pdf
关键词: High-Side     Current     Sensor
