关键词: thermal noise, noise voltage, white spectral density, Johnson resistance, temperature, 1/f corner frequency, calculators, analog circuit design, HP50g programs, design tool, circuit analysis, signal test measurement, bandwidth, clock, jitter, analog referred
摘要:热噪声计算器( TNC )艾滋病在电阻和其他噪声源中的热噪声分析。该方案是使用与HP ® 50G计算器或免费的PC模拟器。
AN5059.pdf
