This white paper provides an overview of the RealDigital technology used in Xilinx CoolRunner™-II CPLDs. RealDigital is the patented design technology used in Xilinx CoolRunner-II CPLDs that enable highperformance and ultra low power consumption in programmable logic devices. RealDigital is a key technology for CoolRunner-II CPLDs that minimizes system current demand and allows small chip-scale packaging options. Low-power designs are enabled through RealDigital by using true CMOS both in process technology and design technique.
wp171.pdf
共1条
CoolRunner-II 真正数字化技术
关键词: CoolRunner-II 真正 数字化 技术
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
