In embedded systems, designers can reduce component count and increase flexibility by using a microprocessor to configure an FPGA. C code illustrates the use of either Slave Serial or SelectMAP mode. CPLD design files illustrate a synchronous interface between processor and FPGA.
xapp502.pdf
共1条
Using a Microprocessor to Configure Xilinx FPGAs via Slave Serial or SelectMAP M
关键词: Using Microprocessor Conf
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
