This application note describes a cost-optimized copy protection scheme that helps protect an FPGA against cloning. The design leverages an external secure serial EEPROM. The included reference design uses an optimized PicoBlaze™ 8-bit microcontroller. This application note provides a hardware design with associated PicoBlaze software code. The code loads a secret key into the secure EEPROM and authenticates the user system with the secure EEPROM.
xapp780.pdf
共1条
FPGA IFF Copy Protection Using Dallas Semiconductor/Maxim DS2432 Secure EEPROMs
关键词: Protection Using Dallas S
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
