【应用笔记】为高速通道设计优化由表面贴装焊盘引起的阻抗不连续(Optimizing Impedance Discontinuity Caused by Surface Mount Pads for High-Speed Channel Designs)
由于数据传输速率不断增加,如今的高速板设计师对升级他们的设计来满足不断增张的带宽需求,面临巨大挑战。
As data rates continue to increase, today’s high-speed board designers
face tremendous challenges upgrading their designs to meet increasing
bandwidth requirements. When implementing high-speed designs, any
small discontinuities in the physical geometries along the transmission
path can significantly degrade the signal. This degradation includes loss
of signal amplitude, reduction of signal rise time, and increased jitter. As
a result, you must be able to identify these discontinuities in the
high-speed channel and provide ways to mitigate their effects for better
signal transmission.an530.pdf
共1条
共1条
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
