电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » 【应用笔记】多器件/阵列的LED测试系统
2012-06-08 18:39:27     打赏
In multiple device tests, such as those that involve burn-in, multiple parts are measured simultaneously over a specified period. A continuous current flow is usually mandatory to drive the DUTs, but multiple light detectors may be multiplexed to a current meter through a switching system. The appropriate choices for switching system and meter will be dictated by the dynamic range of the currents of interest.
在多器件测试情况下,例如涉及老化的测试,我们要在规定的时间内同时测量多个部件。驱动DUT通常需要连续的电流,但是多个光学探测器可以通过开关系统复用一个电流计。用户可以根据所测电流的动态量程选择合适的开关系统和电流计。
Various switch options are applicable to testing multiple LEDs. For example, the Model 3706 System Switch/Multimeter has six switch module slots, so it can handle up to 576 multiplexed channels or 2688 matrix cross-points. Like Series 2600A instruments, it includes an on-board TSP and a TSP-Link® inter-unit communication/triggering bus, which allows integrating these instruments into a system quickly and easily. This integration allows tight synchronization of operations between the instruments and lets them operate from a single test script. Figure 3 illustrates a three-LED device test system with one photodiode (PD) channel.
多LED器件测试可以选择多种类型的开关。例如,3706型开关/万用表具有6个开关模块插槽,因此它最多可支持576个复用通道或者2688个矩阵交叉点。与2600A系列仪器类似,它也内置了板载TSP和TSP-Link®设备间通信/触发总线,利用这套总线可以快速而方便地将这些仪器集成到一个系统中。这种集成支持紧密同步的仪器间操作,并且能够让它们在一个测试脚本的控制下进行操作。图3给出了具有一个光电二极管(PD)通道的三LED器件测试系统结构。
生产环境下高亮度LED的高精度高性价比测试鈥斺敹嗥骷/阵列的LED测试系统
Figure 3. Block diagram with scalable Model 2602A SourceMeter channels for an LED array test system.
2602A通道A、2602A通道B、2602A通道A、2602A通道B、TSP-Link
图3. 采用可扩展2602A数字源表通道构建LED阵列测试系统的模块图
关键词: 应用     笔记     器件     阵列     测试系统
